NoahDL88
Everything posted by NoahDL88
  1. I'm happy about the hatch back, not since 89 has such a fine car graced our shores. now, to figure out if Mudrat will lift it and if Super swampers will fit with minor trimming.
  2. NoahDL88 replied to aja573's topic in Off Road
    http://www.ultimatesubaru.org/forum/showthread.php?t=24980
  3. Amortization (sp) basically if it costs 1 million to develop a part and 5 dollars to make it, that is a cost of 6 dollars for 1 million parts, if you make 2 million then it becomes 5.5 dollars. not quite just one dollar for the last car, but you get the idea.
  4. the "borrowing" of bolts fromt the PAP is a hotley debated issue, some things i don't mind taking, but i try to pay for most stuff, cause if they loose too much business then they go out of business. as for bolts, i don't think any of ours are torque to yeild so you should be ok, head and block bolts may be worth getting new though if your getting more boost or higher compression.
  5. Only the SPFI disty has the hall effect sensor to get the fuel pump to pump, so a carby or mpfi won't work. so yes, you need to swap gears, I have the gear as i had planned on doing the swap myself, but never had the time/patience. iirc you need to redrill the hole, but i don't remember if it is to get the rotation right, or the depth. I'm pretty sure its for the depth, cause if its not perfect, it will chew up the gear all sorts of quick.
  6. i got one of those at the dealership free about a month ago, been using it as a wallet ever since. the subaru credit card fits great inside it.
  7. Huzzah for the DL EA-82, best of both worlds, yeah i got the quad headlights, stock.
  8. call up the subaru guys, www.subaruguy.com they do these swaps all the time, he should be able to hook you up with the details.
  9. Please, Please do a search you will find all that you are looking for, and will make everyone like you better.
  10. Austin, maybe you could move up to the Mighty 2.2, EJ18 is for sucks.
  11. the most awesomest 2 door pickup ever, but in japaneese of course.
  12. http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b7a4f46.89471656/&FileType=Article&File=ARTICLE_3f53a13f7c7491.41102012.art Scroll all the way to the bottom, who ever made the page was not teh S-M-R-T
  13. I'm in detroit too, i'm free till i have to go to bed, so any time before 9 give me a call and i can come check it out if you'd like. 231-580-62 four nine.
  14. could be intake, or head gasket, i'm pulling for the intake cause its easier to fix, but i'm leaning towards head gasket.
  15. Why stop at 3.90, would it be possible to put in 4.11 and the real low range, 1.59? What exactly needs to be done to retain the AWD and get the 3.90 gearing?
  16. The actual cooling system must be under pressure to function properly. as far as the overflow tank, why? if you have that much pressure in the bottle then you need a head gasket, not another hole.
  17. the EJ 5 speed will bolt up easiest to the engine, but the tranny cross member will need to be modified, as well as the inner cups for the front axles, you could run an old 5spd, but i'd worry about the power it could handle. you would need to get the adapter plate from mudrat if you did that though.
  18. In my(Austin's) EA-EJ swap i'm running the 2 cats, the flex pipe broke, so the cherry bomb is not functional, it sounds all sorts of mean, and it stays under the max decible limit, its not too bad on the highway either, i can still listen to the radio.
  19. NoahDL88 replied to TurboSPFI's topic in Off Road
    try the 2wd axles from Subaru, they are stronger, and have better quality control
  20. I'm teh nerd, so i look at the subie like spock, he "died" in the second movie but wasn't really dead, cause his Vulcan soul lived on, so too shall your Subie's soul live on. or there's the organ donor approach, she must give her life so that others might live. either way, i'm sorry for your loss I shall wear black for a time fitting to mourn your loss.
  21. at least for the sake of consistancy you could have said a 6 and 12 speed.
  22. Glad you're back, i was starting to worry. Now how bout the PAP weekly update
  23. I'm in Detroit, which is kinda near northern Ohio, let me know if you'll be needing anything. 231-580- Sixty two fourty nine
  24. I guess i could too, i got both sitting in my driveway, i was just hoping that someone else had tried it. Somewhat related note, has anyone tried the EA-82 master cylinder in the EA-81?
