Everything posted by NoahDL88
1990 Loyale No Power but good battery
you did check the fuses under the dash?
Start at the + terminal, and follow the path, when you don't have power anymore that is your issue. Check the fuse box under the dash. There is a large draw burning fuses, so ultimately that will be your problem, for your sake I hope its a component and not the wiring harness.
Gave up searching...
It's your vacuum solenoids for your 4wd system, IIRC don't recall the routing, but it might be on the sticker on your hood
huh, whats it is?
NoahDL88 replied to Suba_GL_87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn all seriousness, I think if you replaced the transmission it could be a loose line or broken hose. There is also a separator plate on the back of the engine that frequently leaks, but if you've looked at the rear main and didn't see any oil it probably is not the problem.
Removing engine without hoist
I would imagine this question was answered when you were still in middle school, Bush was in office, and the 05 WRX was brand new Just sayin
fi?
That's being generous, and optimistic, hopeful, and perhaps even delusional. I'm going to be swapping SPFI to my EA-81, I've done the EJ route, and it really is a night and day difference, but I'm trying to eek out some good fuel econ with the EA-81, and I think SPFI will do better on the 1.8 then MPFI will do with an EJ
The Old School Reunion Show
Can we please plan a Subaru event this summer that isn't a drill weekend?
Gorilla Offroad Company - website launch!
Perhaps you should contribute to this board, instead of using it as free advertising. Not one of your posts has been in any forum other then vendor, and you can't even be bothered to donate some money to the forum for your free advertising space. You are here for no other reason then to make money, plain and simple, if you were actually passionate about Subaru's you might have taken the time to post somewhere else on this forum As you said, perhaps YOU should go to nasioc, I've been here for 10 years and you've been her for what, ten days?
How many of you will bring off roaders to WCSS this year?
It's a drill weekend for me, I plan on getting my girlfriend to drive the Pinz up and taking my bike and the ferry from base to and from for a quick non AWOL experience. Save some mud for me
Does it not rain where you live? If I hydro lock my engine will you cover it's replacement?
I can't imagine it's terribly efficient once the element is soaked in from the rain though
4x4 survival kit
At some point the additonal weight of gear becomes a liability. The drivetrains on these vehicles was not designed for extreme offroading and oversized tires, add to that 600 pounds of extra gear plus 3 friends and you are well outside the design parameters. You can prepare yourself so well that you end up needing the gear because you have it. Sure you could bring both a front and rear axle, but why not leave the rear at home and save the 15 pounds. The less you bring, the less you will break. Yes, bring something to help you survive, but your car doesn't care if it spends the night on the mountain or in your driveway.
How can I get best deal on craftsman tools?
Garage sales. It will take a lot of time, but if you have more time then money ( like most of us) spring cleaning will be in full force soon, and you'll be able to score some sweet deals. Best part is, if you find old craftsman, snap-on, Mac, Matco, whatever, they have lifetime warranties so if you pay a little for something broken/worn out you can get it replaced for free!! I hated garage saleing when I was younger, but I realized it was just the sales my mom went to, if you go to the more guy oriented ones there is some pretty neat stuff to be found. (silver for example, if it's real silver flatware you can do pretty well if you buy low)
total noob question be gentle
The six demon bag?
EJ 22 Cooling ...XactStant
NoahDL88 replied to jpwoody's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat is your coolant mix ratio? Double check your burp by lifting the font of the car, or parking it on a hill nose up, a curb would be plenty high. Crushed hose? if they are not on straight it could have gotten kinked.
What size roll pin.
Jack the corner up and try to shake the tire, any motion is bad, the in/out will be wheel bearings, other motion could be ball joints.
What size roll pin.
I was 18 once and knew everything Then I got older On the ground is fine, set the parking brake and leave the car in gear.
NWWO 4th Mid Summer run July 6th 7th and 8th Evens Creek ORV Park
If you're going, I'd better be there too, Polly may have to tow you out again Oh, and I'll bring some dry socks, just in case. :-p
Wcss14??????
I'm hoping to have something with both front and rear lockers, so I hope there is a mud pit.
15 Pugs tire shop would not mount them
Some of the 15 inch pugs are in-fact 390mm, so they are 15.3 inch wheels.
Correct me if I'm wrong...
With that offset, even without you'll probably have to do some cutting. Why not go 4 inch? it can't be much more expensive and will help a lot with the amount of trimming needed. With a 30 year old car the springs will make a big difference as to what works from car to car.
that is it. 8)
+1 on using a ATV/Motorcycle jack for a tranny jack, I've done a few clutches that way Should have gone with yellow, more torque :-p
Brand new Impreza starts with difficulty
NoahDL88 replied to Flopka's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWarranty!!! Get it to the dealer, get the complaint written down, that way if it does manifiest itself later, even after the warranty expires you will most likely be able to get it taken care of. Also, brand new vehicles should not be a pain, let them figure it out, have a cup of coffee, and see if you can upgrade to the WRX!!
- Tahuya Feb 4th
Tahuya Feb 4th
Before!! Meet Polly the Pinzgauer!
