				Posts3410
Everything posted by NoahDL88
	Tach could also be a loose tensioner on your timing belt DAMHIK
	  waterproofing 1990 loyaleNoahDL88 replied to logang1k's topic in Old Gen.: 80's GL/DL/XT/Loyales... Stock, if you don't get too crazy you'll get 3-5 dunks out of it before everything fails. If you spend about 50 hours on making it "waterproof" you'll be good for about 6-8. It is far easier, and this is the voice of experience, that you either: 1 replace car after you dunk and kill it. 2 don't dunk it. For my money, I've decided to go for option two.
	  Waterwagon 3 Build-up, and the SJR+EJ Lift Thread!NoahDL88 replied to Ratty2Austin's topic in Members Rides It happens, I used to be shy, but now I'll start up a conversation with anybody riding a motorcycle, driving a subaru, or wearing anything from Michigan.
	  Waterwagon 3 Build-up, and the SJR+EJ Lift Thread!NoahDL88 replied to Ratty2Austin's topic in Members Rides Yeah, that was us, I was in the blue Leggo next to his
	  waterproofing 1990 loyaleNoahDL88 replied to logang1k's topic in Old Gen.: 80's GL/DL/XT/Loyales... you'll need to run hoses up the "A" pillar for all your vents, tranny 2, rear diff, the powersteering cap is closed pretty tight, i wouldn't worry about that as much, just make sure you have a good seal on that one. Seriously though, its a waste of time, you can get every fluid happy but you'll still be soaking connectors and wires, so you may have to junk the car anyway, except it will have some good looking fluid in it instead. you can get 207S bearings for the front wheels, they are sealed and are less likely to be ruined by water crossings. An older diesel has no electronics so you can cut the distributor entirely. Its fun going through water, don't get me wrong, but its just not worth it to "waterproof" your car
	we need to let this thread die, the OP already tried stuff against our recommendations and now his engine is dead Where is the I told you so smiley?
	  Marvel Mystery Oil in a Gen 1 Brat???NoahDL88 replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's Naptha is a petroleum distillate. What ever it is, its good stuff. I'm also a big fan of Seafoam, but that's for a different application.
	  Marvel Mystery Oil in a Gen 1 Brat???NoahDL88 replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's It looks and tastes like trany fluid. Also, based on the MSDS both MMO and Dexron have a great deal of Naptha and mineral oil.
	The Loyale is single range. Nice body though.
	  $900 for clutch and labor?!NoahDL88 replied to zman111's topic in Old Gen.: 80's GL/DL/XT/Loyales... Can you do it in 8 hours? Did you spend good money on an education to learn how to fix cars? Have you taken the time to get certified by your local state and or ASE chapter? Have you taken the extra classes provided by dealerships to make damn sure that when someone comes in with a car that you are trained to fix it and not taking a shot in the dark? Have you spent between 5 and 15 thousand dollars on tools out of your own pocket? Did you spend extra money on tools that are specialized so that you can complete the 16 hour job in 8? Mechanics are a bargain considering what you get for your money.
	  $900 for clutch and labor?!NoahDL88 replied to zman111's topic in Old Gen.: 80's GL/DL/XT/Loyales... flat rate labor times are standard, so the difference in price is usually due to different labor rates, between 80-120 dollars an hour. If you go into Schmucks and buy a clutch kit you get it pretty cheap, but the Dealer/Mechanic wants to make money on parts too, so there is a markup there. If they replace or resurface the flywheel there is going to be between 50-150 dollars into that. 900 bucks for a clutch seems high, but not horrible. If you agreed to it, you're liable, if stuff was done without your permission above and beyond the quote, you can ask them to return it to the condition it was in and not pay. Separating thoughts into different paragraphs make it easier for the rest of us to understand what you're trying to say.
	  Marvel Mystery Oil in a Gen 1 Brat???NoahDL88 replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's its still mostly tranny fluid :-\
	  Marvel Mystery Oil in a Gen 1 Brat???NoahDL88 replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's Its a cleaner, more than an anti wear additive, i believe its mostly tranny fluid.
	  Marvel Mystery Oil in a Gen 1 Brat???NoahDL88 replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's It can help with lifter tick, but ultimately we can't know if it will help your brat unless we know whats wrong with it. If it has a flat tire, MMO probably won't help.
	I usually go with Bowwow on Filbert road. That is if i'm not going OEM
	192 is out of the service manual.
	I'd stick with the stock one, which appears to be the 192 degree thermostat. It will run more efficiently and have more power.
