Everything posted by NoahDL88
Fuel, spark, no start
I think very highly of the Japaneese, i just think that you are showing your age and your ignorance by calling Japaneese people Japs, maybe you forgot about the internment camps during the war. I hope you can understand that this is a very diverse family web site, and that using derogatory comments, weather you find them to be or not, will not make you welcome here.
Hate to follow you around like a babysitter, but we don't use the term Japs either, many many people have Asian connections, and find the term derogatory, especially due to its historical background.
Gear lube Q
Its not the gears that need the protection of the Friction modifier, is the clutch pack LSD bits, gear or no gear, you're not gonna go anywhere if your clutch packs are torn to shreads. BTW, as i said before, you don't need the friction modifier in the tranny cause there is no LSD, and GL-5 doesn't have friction modifier, cause if it did, you wouldn't need to add it now would you?
LSD's???
Whoa there tiger, make sure to get all the facts first. It will physically bolt into any EA subie, provided its 4wd, but it won't work on all of them, LSD's came in turbo cars,which were all 3.7 ratio, they won't work with non turbo cars, or cars with MT's unless the LSD is taken out of the 3.7 diff and put into a 3.9 diff, if you miss this rather important step you'll blow up your drivetrain.
Denver mad scientists - transmission lab: Lab ingredients/forumula FOUND!
I have an RX box at my 'rents house, but there in San D and i'm in Sea-towne. so i'm out, but i have the "hard" tansmission to find. i'll do what i can from Seattle, but i still need at least 2 transmissions first.
What If.....
I wouldn't do it for power, fame or for attention, i'd just want to be helping the needy, in america 100 bucks wouldn't do squat, thats true, but 98% of the world lives on less than 30 cents a day, so for those 98% it would sure do a lot
How do I mount this radio in a loyale?
That looks like it goes in the 4 subie mounting holes, and if you've broken the tabs that they go in, as it sounds like you have, then you are out of luck. you can either replace the dash, or find another way to mount it.
Question regarding timing belt replacement
NoahDL88 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepending on mileage, its not a bad idea, there probably gonna be removing the radiator anyway, so why not. I'm a mechanic, and when i do big jobs i like to reccomend the little things that go around the big stuff, If i'm gonna pull a tranny, i'm gonna reccomend a clutch if its been a while. I'd rather install it now, when its easy to get at, then later when its all back together and the customer insists that i broke what ever bit that they didn't want replaced at the time. Make sure you get your seals done, and a water pump isn't a bad idea either if its got over 100K
Gear lube Q
GL-5 is gear lube period, thats like saying ATF is a good idea for an auto tranny :cool: Its the API spec for gear to gear setups. In a LSD, which btw, not in trannys, unless its an STi do need, and require the "smelly stuff" or you're gonna be repacking clutches real soon, theres a reason why engineers and not 16 year olds design these things Retarded? i'll let my autistic friend know that he is actually LSD friction modifier, i'm sure he'd get a kick out of that.
Hill Holder repair question
I may have one, mine was leaking, but it fixed itself, If its not at my parents in San diego, i'll let you know.
Website of the Beefaru 88 wagon is DONE!
My hope was to use the RX center diff, cause i need lockability front and rear, for offroading and the like. But as i see it, or what i'd like: RX center diff, W/lock 4.11 or 4.44 final drive 2wd first gear 1.59 low range Just need a legacy 5mt and a spare EA-82 dual range, as i'm not too worried about the 2wd first gear bit.
What If.....
If i had an unlimited budget, i'd fill the car to the brim with 100 dollar bills, and drive around and give them away, specifically in urban areas, starting in Seattle, and working my way around the globe until i got to the tip of russia, then i'd get it to float, and drive down from Alaska to tierra del fuego.
You should be able to bypass the hill holder, i wouldn't see why you couldn't. Don't really need a hill holder in Michigan anyway.
Gear lube Q
Rislone, the engine restore stuff, also seems to help your syncros, so if thats an issue, you can add a pint of that and it should help.
Ok, girls pulling their shirt up are a dime a dozen, you gonna finally spill the beans on how you got the legacy final drive in the RX box?
Thats a pretty vague question, i'm sure google would have 10 million pictures that fit that description If you find one let me know :cool:
Welded the rear, WOW!
The power of the EJ22 combined with the low range 1.59 and a welded rear in an EA-82 body let my subie crawl up the same hill that others with the 1.8 and open diffs had to charge up. More power and more traction FTW
I need a answer please, help me!
NoahDL88 replied to chadwick2004's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould be a resonant frequency in the intake, if you took out the snorkus that could have effected it. Otherwise, you might make sure all those funny bulbs and whatnot are on the intake tube between the air filter and the TB
Ridiculously high mileage on one engine, with no head gasket change
NoahDL88 replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd have to beg to differ, production numbers alone dictate that there are far more EJ25's on the road, which through sheer attrition puts more EJ25 head gaskets on the road than the EJ22.
96 Legacy dies going uphill
NoahDL88 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy ASE .02 cents lean towards the fuel filter.
H6 Swap...
NoahDL88 replied to BruceyWV's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would urge caution, as the key may have a RFID chip in it, and if the ECU needs a signal to crank from the key, it won't work without it.
Assembly Plant Tours
NoahDL88 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru's are made in either Lafayette IN, the legacy, outbacks and tribeca, and the impreza's are made in Gumma Japan, along with the forrester, those 2 cities are probably the east coast port of entry.
Questions-
Welcome I don't have a parts list, but cam seals, crank seal, waterpump, oil reseal kit, mickeymouse gasket and of course timing belts are what you're gonna need, although i'm sure i left something out. The wheels came off of a Pugeot, either a 504 or a 505, an 80's model that was neither fast nor spectacular, just be sure they are not the 390 "metric" wheels, they only have one tire, made by michelin that fits. Fenders off of any EA-82 subaru should fit, 86-94, although the coupe may be different.
Outback struts on a Legacy? YES!!! Thanks.
NoahDL88 replied to SuBrat84's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn the rear, you're gonna need to swap the strut cap, the bit with the three studs. In the front its direct. You may have to bash out the inner fender behind the strut a bit to make it work, but it should get in there. to swap the strut cap, you're gonna need a spring compressor, if you don't have one then....
Anyone from washington!
you might work for at least 5-10 years at Subaru, get your official subaru certs, and then go solo.
