Everything posted by NoahDL88
I was talking with one of you guys about custom axles for the 5 lug swap with the NA 5MT inner cups, i think you had suggested GCK axles would do the custom work for me, just wanted to make sure before i go looking. I got the itch back, the bike will be on the back burner until spring.
Mudpit Videos are here!!
NoahDL88 replied to TheSubaruJunkie's topic in Meet n' Greet. Your USMB Welcome Center
where is the noah pulling the yota? -
The positive side of WCSS, the fun stuff.
NoahDL88 replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
This was by far the best WCSS ever Won a speaker worth more than my car Pulled out a toyota got the car good and muddy had a car this year, instead of flying made it home no problems pulled out a toyota didn't piss off ken, (to the best of my knowledge) met a lot of new people got to hang out with a lot of old friends I have to say, that i would still come to this even if we all stop driving Subaru's the first year it was about the cars, but every year since its been about seeing old friends and making new ones, I couldn't have been happier, definitely one of the best weekends of my life, and the best WCSS by far a million thanks to the guys that organized it, Ken and Zap, you are far too humble. It feels like a family reunion when i go to these things, i hope to see a lot of you before the next show, a year is too long to wait. -
WCSS 8 Identifier
NoahDL88 replied to WheaT_BeeR_MaN's topic in Meet n' Greet. Your USMB Welcome Center
Stickers, and I pulled out the Yota:banana: Should cover everything. -
Positive Crankcase Ventilation. I'm with the clutch croud as well, check for fluid levels in both the engine and the tranny, and if they are within the lines and you are not still making smoke, i wouldn't worry too much
Age has nothing to do with it, height somewhat, but the big determining factor is weight, the airbags are tested to work within preset parameters of a 95th percentile man, 300 lbs and a 5th percentile female, 110 lbs anything higher, and you might check out 24 hour fitness after you see your doctor, anything less, you should sit in the back.
Umm, you might shoot him an email, or call him, you'll get the most accurate answer, and i won't charge you a 15% middle man fee
Tables at Hoodriver? (Answered, Thx)
NoahDL88 replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There will not be tables at each site, but there is an area IIRC that has tables for us to use. -
Greeting Fairbanks!!!
NoahDL88 replied to Rolloverbratboy's topic in Meet n' Greet. Your USMB Welcome Center
John, let me know when you get all settled in, then i'm coming up to visit. -
IIRC, the rods and pistons are forged stock, so i wouldn't worry too much. Its the head gaskets that you'll have to worry about
Incorrect Even if your state does not test, if the cop that pulls you over wants to be a wongleflute, he can inspect your emissions systems and make sure you have all applicable bits. In Michigan, which will probably be the last state to ever have emissions, you are still required to have all emissions equipment on the car, at least for 10 years from manufacture, i believe. Just cause they don't test, dosen't mean you can legally take the bits off. could you get away with it, probably.
Friday caravan to WCSS?
We should have a few with a CB, i have to mount mine, but i got the radio ready, just the antenna needs to go up. Ch 5 or 2 depending. I'll probably be on 5 unless others want 2 instead. -
I left em, cause its no harder to leave them on then it is to take them off.
Yeah, i hear that, mine split where the two pipes come together. I'd caution welding, its stainless steel, and that seems to be harder to weld, and when you do weld it, its prone to stress fracture, hmm, sounds like its not a good metal to make exhausts out of. If i ever meet a borla employee, i'm gonna sucker punch him.
there really is no way to make the EA-81 you have MPFI unless you swap heads and manifolds, with all the assorted wiring and stuff. At that point, it would be just as easy to drop in the EJ22 and with that you get an additional 45 horsepower, so it should be a no brainer.
If you rebuild the motor, make sure your cam pullys are on the right side, if there not you won't get any spark. go through the pinpoint tests in the manual, that should help you track down bad components if there are any.
Depends on the location, but there were a few that i was able to punch through the sheet metal behind the captive nut, and run a smaller bolt with its own nut on the inside of the car, not the best, or the safest, but it got the job done.
Front-end grinding that went too far...
NoahDL88 replied to Pokie34's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you're gonna need an axle and a hub, along with bearings probably on the side thats affected. shouldn't be too bad, although when you're done make sure that the 36mm nut on the end of the axle is good and tight, which could have been one of the causes of a stripped hub. You can probably go junkyard on the hub, for all the parts actually, but it wouldn't hurt to have a "new" axle for the peace of mind. -
i need some ideas for my bad running car
NoahDL88 replied to WheaT_BeeR_MaN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No compression, sounds like a head gasket issue, if you're running on 3 cylinders that would certainly make it run rough. Did you try a wet compression check? could one of your valves be sticking? I'll assume that this is your MPFI GL-10 turbo yeah? the more info you give us, the more help we can be. -
I can only offer the two options that i can see as an issue, which are the two issues i had when i installed my lift. 1, there are blocks that fit where you put them, but were supposed to be in the places where the blocks you have don't fit. 2, you need to lower the suspension as a whole, by swapping each short bolt with each long bolt, without the blocks, and once the entire end of the car is lowered, then you can install the blocks, and tighten everything up.
