Everything posted by NoahDL88
Bit of info for those who want to know
Last year i asked if anyone wanted to get some of these and bring them over, they are about 3k AUD, plust another 1.5K in shipping, so at the risk of . Unless we get a bulk shipment, there is no one that is gonna buy one for 6000 bucks.
Uber-getto snorkel
On one of my previous subies the filter was exposed, but it had a hood on it, however the front of the element was exposed, so when i was moving forward in the rain it picked up water which is no good at all. Make sure to have the opening facing down, really, people don't seem to listent when i say this, and then have to change their design after the first rain 6 months later.
new 2005 outback a/c not strong enough
NoahDL88 replied to laserone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd by "new" cars, that would be anything built since around 1995, just an FYI
Northfork Snow Run NW WA Deming
If we made some of these offroad trips on a Sunday would that be so horrible? i work saturdays, and can usually get them off, but that means a hit to the paycheck. I have no idea where demming is, but i could be counted as in, and if Amanda needs a ride, i got extra seats.
SO "Subaruham"....
http://www.bellinghamherald.com/apps/pbcs.dll/article?AID=/20060402/LIFE/604020347 for those of us that don't live in B-ham
Cut,Chop,Bash?
http://www.ultimatesubaru.org/forum/showthread.php?t=24980
Lookin into droping an ej22 in my brat...
My EJ runs at about a quarter up from the bottom, and when it hits 75 % i know its running real hot, so no, there different, but if you establish a baseline, then you can manage with it using the EJ22 sensor and the EA-8X gauge.
88, what did you use for the metal part of the coolant hose? mine has a 1.25 inch pipe but it really necks down the flow to maybe only .75 of an inch, and yours is so much prettier. What did the bits for the oil pressure sender cost you?
Red Robin Meet and Greet March/April?
I'll still be there, rain? what rain, its called a tailgate for a reason :cool:
Help Plz: P/S Leak
NoahDL88 replied to T.J.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah buddy!!
by ************akchi hello weber
I believe that the redline adapter is about 1 inch in height, although if you've lifted your rig, you can make one taller and increase the plenum volume, however that will mess with your jet settings, and you may have to go bigger or smaller depending on how it effects your vacuume signal.
Clutch disks.
NoahDL88 replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're worried about slipping, be sure to use the XT-6 pressure plate, it clamps down about 50% more than the normal EA-82 plate, i don't have a supercharger, but i've been running an EJ swap with swampers for about 7000 miles now, and i've never had any slip issues, ever.
Home-brew DRLs for '95 Legacy?
NoahDL88 replied to Rob Kuhlman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust turn the lights on, and leave them there, its not DRL's but they go off so you don't have to worry about jumpstarting because you left them on. I've had the light switch on my 88 on solid since i got it, maybe have had it off 5 times tops.
EJ22 exhaust mods???
NoahDL88 replied to Beegeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts come up before, but i thought i'd re clarify again anyway. Backpressure is bad, but its not necessary, you don't need backpressure for proper operation of your engine. What is important is flow velocity, you want your exhaust to flow between 240-260 FPS anything less and you get wind shear, which we see as backpressure, and anything more and the air becomes stagnant and looses its velocity.
Help Plz: P/S Leak
NoahDL88 replied to T.J.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you just tried to tighten the nut? it could be as simple as that, or as you said, the junk yard. IIRC there is an "O" ring in there, you might check to make sure that its still good, cause if it isn't that could certainly be the cause, and even at the stealership an "O" ring can't be more than a couple of dollars.
a long over due apology
It takes a strong man to own up to his mistakes. Now, i'm sure that the mods would have no problem about a properly identified post in the off topic section, shoot there's enough of us that we should get some sort of team or support together even. Keep us posted, just no V12 subies
It may be a hair closer http://www.ddir.com/store_holman_road.html 5PM, bring cash, they don't take plastic, its cheaper than RR though, so it wins. Do the no rain dance friday night and we should have a sunny saturday.
Uh Oh, Warming Trend
BAD IDEA For 2 reasons, your engine will never heat up, so you will get fuel puddeling and horrid mileage, and also the T-stat acts as a restriction, giving the coolant enough time to pick up heat, so without it you will be running cooler, but you'll have hot spots.
Which VSS, where to get one?
NoahDL88 replied to bagtagley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are 2 types of VSS's the ones for ABS, those are on the corners of the car near the brakes. The type that controls the spedo is in the tranny, I don't know how easy it is to get to, but i'd suggest that you make sure that your spedo cable is still attached, I don't know if your model has one, but it'll be cheaper than finding out later.
maybe its just that its getting warmer. Make sure that your fan comes on, and it wouldn't hurt to pull your T-stat and make sure its opening and closing, or just get a new OEM one and put it in.
Some Mild Offroading in the New River Gorge
I just left michigan, now i'm on the real left coast, the Pacific, not lake michigan. There were some good places up where i went to school, in Big Rapids, but theres got to be better places around, but after offroading out here, i don't think i'll ever be able to go back, too sandy and flat.
Dang, i can't do anything right I work saturdays, so later is better for me, and since i took most of this week off, i don't think the boss will be too keen on letting me take saturday as well.
My First Subaru, what to buy for it?!?!
NoahDL88 replied to spikeyhaired1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA K&N filter will do nothing for horespower, and will let in much more dust and dirt, which will shorten the life of your engine immensely. my .02 wait till it gets out of warranty, you don't want any legitimate warranty claims kicked because you put on some aftermarket bits. Straight line, it should already be plenty quick, and there's nothing you can do short of a turbo that will make it quicker in any quantifiable amount. Go with suspension and wheel/tire upgrades and you won't be dissapointed.
engine light is on constantly whats wrong!??
NoahDL88 replied to subarulover1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are probably over 100 individual codes that could be wrong, however, i do believe there is a way for you to check for codes yourself, however i don't recall how. Seeing as the cats were replaced recently, i'd make sure that your o2 sensor is plugged in, as that could very easily been left unplugged.
Rear Diff Spline & Axle Fused Together!!!!
I'd try a 3/16th drill bit, and make sure that you have the entire pin out, and just keep PB blasting it every few days and it will eventually come out. really big hammers don't seem to hurt either.
