Everything posted by NoahDL88
How many have you meet and greeted.
NoahDL88 replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
I guess we see how well i stack up -
warming up?
NoahDL88 replied to 97OBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just my .02 cents, but every single one of my over 20 instructors at school, who all at one point in their lives designed, tested or otherwise worked in some fashion with engines, all said that warming up an engine for 5-10 minutes is bad news, at low rpm, and low temps the oil performs poorly. The reccomendation is, let it warm up for 30 seconds to a minute, and then drive away gently until its warmed up. the best thing you can do to an engine is to get it warmed up quickly driving gently and keeping the revs above idle. -
So, as i'll soon be in the land of plenty (Seattle) I'm hopeing to find 2 transmissions, and a few random parts. I'd like to find a 5MT with 4.44 gears, along with a matching Rear Diff A N/A 5mt D/R with the 1.59 low range A LSD for the Front, i know this one is a pipe dream, but you never know. So, you ask, what pray tell is my plan? Front LSD 4.44 final drive RX center locking Diff 1.59:1 low range. now, putting this all behind a EJ22, and a locked rear end and who needs a "real" transfer case. Assuming this is feasable, and or do-able with out millions of hours of work, i'm sure i'd be happy enough to build these for the board. As of now i only know that the better low range can be swapped, so don't get your hopes up too high, and if anyone else wants to dive into this one, please by all means go to it.
I believe Bilbo put it best, "I don't know half of you half as well as I should like, and I like less than half of you half as well as you deserve" Clearly, about the second half i'm mostly kidding. But about the first half, I truely mean it. I'd be lying if i said that the move to Seattle wasn't based somewhat on the USMB and the wonderful people I have met through it. -
Looky... Looky...My new Exhaust (with pics)
NoahDL88 replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
But most everyone is in the US not AU, so shipping would be horrid. -
The rear driveshaft should be 2 piece. if it is, you can pull the center section of the drive shaft, behind the carrier bearing and in front of the rear diff, there will be a total of 8, 12mm bolts. be careful not to strip them, as after 14 years, it will happen easily. it should be clear very quickly if this is done right, if you see splines the wrong end was pulled.
XT6 Clutch in EA81 4SPD (?)
NoahDL88 replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The XT-6 Pressure plate will bolt on to the EA-82 flywheel (99%) sure. When mateing the EJ to the EA-82, you use the redrilled EA flywheel, and the XT-6 flywheel and pressure plate. Interesting to note, but the legacy has the same spline as the EA-82 transmissions. so you may be able to run a high po legacy kevlar clutch. -
Pros/Cons on Custom Exhaust???
NoahDL88 replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its a difference in Exhaust Velocity. a proper funtioning exhaust needs to flow at 240-260 fps, any slower and it becomes "stagnant" and any faster and the friction losses increase exponentially and create "backpressure" When you remove the cats and other restrictions, you move the band at which the engine flows best, in that 240-260 fps sweet spot, so at low end the flow becomes stagnant. -
Miles Fox in training?
The 4spd and the 5spd have different splines, so the XT-6 won't fit on the 4 speed. -
It seems to me that, (flame suit on) that the Evo MR and the STi are the exact same car, with a different badge. out of 100 articles, the Sti wins 50 times and the Evo wins 50. the vehicles are so similar that it boils down to what your preference is. a Quality Japanese product built in Gumma, or a shoddy Chrysler mut. There's a reason i don't write for MT.
OMG its Gorgeous.
I feel bad leaving without meeting you, it'd be a shame to go back to seattle without seeing your brat collection. -
There are already makers of adjustable sway bars, depending on which hole you put the end link in it makes it "stiffer" May be worth looking into, probably easier than connecting 2 sway bars together.
Yes, the 3 lines on the Flywheel, the center should be at the timing light tab thats cast into the block. The passenger side cam should be at 6 O'clock, and the drivers side should be at 12 O'clock. the "orienter" IIRC is the roll pin that aligns the cam sprocket next to the 3 bolts that hold the sprocket on. As for tension, i always go from the crank out, and make it as tight as i can on the sprocket, and adjust tension after on the other side, as for how tight do i get it? i couldn't tell you, but some where between tight, and good and tight.
I've been wanting to figure a way of making these. I tell you what, if i get around to designing somthing that might work, you'll be the 2nd to know.
I have taken college physics, and my degree is in Auto Engineering. and i can tell you that from a design standpoint that is bunk, air is already a gas, so no atomization is necessary, and in a MPFI car, the runners are dry, so the turbulence that is added in TBI to keep the fuel in better suspension is worthless and reduces flow on a MPFI system. From a more practial standpoint, if car company "A" is making 100,000 vehicles, and for 5-10 dollars can add a gizmo "B" that raises the fuel economy of a vehicle 10-20% which then raises there CAFE numbers by "X" then car company "A" pays less in fines, which number approxamately 500$ per vehicle. 500,000<50,000,000 Now let me ask you this, don't you think that company "A" would put them on from the factory, its the same story as the K&N air filter, they don't increase flow appreciably, and they let in more particulates. I'm not saying that a "vortex generator" won't work in all aplications, but I will say this, the applications it works best in, are TBI and Carbed engines, because those are "wet" manifolds and are designed to keep fuel in suspension, not to maximize air flow.
