Everything posted by NoahDL88
Looking for a good intake
NoahDL88 replied to jeep5.9litre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI concur
NoahDL88 replied to jeep5.9litre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat will help response more than anything, but unless you actually do real work to the engine, (spend money) you're not gonna go any faster. The stock intake will flow over 300 horsepower easy. nothing you can do to a NA car between the filter and the TB that will get you more then 2 horsepower You wanna go faster, get a good set of springs, all 4 corners of the car. only then will a complete exhaust and a perfect power chip do you good.
Anybody remember ORSA?
only cause i'm jealous of your "squadron"
I remember
n00b w/ 87 xt needs help!
This would be the easiest. Just a helpful hint, leaks almost always start the farthest forward and the highest up. so a leak on the top of the engine can look like a flood from the transmission.
If you have an Orange 4WD button on your shifter, you have 4wd, not awd, i don't believe the XT DL's came with AWD, as far as your leak, do you have an auto or a 5 speed?
5 speed tranny ?
Please don't double post, one forum is enough.
EJ18 heads on to an EJ22? Anyone done it?
NoahDL88 replied to Matty B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWould the 2.5 head work? that might raise compression too, and flow better than the 1.8
Help with my teaser download.
You could turn it into a torrent file and then random USMB'rs could Seed it.
What engines are in these cars.....??
They both have the EA-82, but the turbo, is of course a turbo, which some would argue as not very reliable, but if you change the oil on time and keep the cooling system in top condition you won't have any problems. Auto tranny, not so much. I've heard a lot of bad things about them, although i've never had an EA-82 auto. My Ex has an 88 GL 2wd with an auto, has about 50k on it and it seems to do fine, the biggest issue there is that there is no 4th gear.
carfax anyone??
NoahDL88 replied to theflystyle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXplease don't cross post, someone will see it no matter what forum its in.
how to add a snorkal to my 83 gl
http://www.ultimatesubaru.org/forum/showthread.php?t=43024&highlight=snorkle+ultimate Here it is, just took a little bit of leg work to find it.
Do a search, i'm sure its still around
Cheap lift
Depending on where "international" is.... Scorpion in Australia / NZ Ozified or AA in the US I personally have 2 lifts from Ozified and have had no problems with either. www.ozified.com
perfect skid pan for a legacy!
This is good information, but you shouldn't double post, one forum is enough
rear end skid protector
You might go to your local dealership and ask them. I've been offroading my 88 for years and never seen anyone break their rear diff, axles sure, but not the diff
Detroit Lockers, and Subaru's
It could be done in car, but any oil, even the little bit left over after you clean it out real well, could start your car on fire. remember, on the other side of the sheet metal above your diff is the gas tank. I'd do it out of the car, not that much more work and the peace of mind is worth it.
Rumblings on other boards...
If i recall, they didn't do half bad either. SubaRubicon indeed.
If I Buy A Lift Kit
The 4 cylinder or the 4 cylinder turbo is an XT or an XT-Turbo respectively The XT-6 has the 6 cylinder, a 2.7, basically the 4 cylinder with 2 extra cylinders.
Wear seatbelt while wheeling?
Thats funny, you won't wear your seatbelt, but you have a car with 6 airbags.
Sure is cool that they don't hate us. I'd like to remind everyone here, that if you feel the urge to go over there and talk with them, keep it nice. we don't want to start a flame war.
Top Speed?
I've never been to a track, so i can't help you there, sorry. i do know that my 88 DL 4wd didn't like anything much above 70 anyway. those wagon bodys are bricks.
power upgrades
NoahDL88 replied to machine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere is a reference signal that the computer needs altered, its a 5V signal, if its on, you need to turn it off, if its off, you need to turn it on. varies by model and year.
power upgrades
NoahDL88 replied to machine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas i suspected, i have a 96 with the 2.2 and the auto, i plan on swapping in the standard shift asap. that hesitation is pretty standard for the auto's, not much you can do. unless you arn't afraid to spend money, i have a borla header and a TWE "J" pipe, dosn't do much for low end, but above 4k, watch out.
Top Speed?
70, as that is the highest speed limit in my area. If you've gone faster we don't want to know about it, falls under the same umbrella as street racing and tresspassing when you offroad.
