Everything posted by NoahDL88
I'm under the impression that new subaru brake lines work on the older ones, so if you've done the rear disc conversion the new stuff should fit, i'm gonna see about getting a set of Forester SS lines and see how well they fit. Gotta get a job first, there not cheap
Make sure that if you switch from DOT 3/4 to DOT 5 you flush the lines with alcohol, not your good tequila, but the stuff you get at the drug store. as for cross drilling your rotors, that was only necessary when pads created large amounts of gas that needed to be disipated. new pads don't gas much if any, so cross drilling is mostly for show, along with your Hondar type R sticker.
Centerforce will make us a clutch!
NoahDL88 replied to Steveman09's topic in Old Gen.: 80's GL/DL/XT/Loyales...
do a search, we use the XT-6 clutch, it can hold 145 hp, so were good to go, if you combine an XT 6 pressure plate and a legacy or Impreza kevlar clutch you'd be good to go. -
http://cobbtuning.com/impreza/brakes1.html#lines http://www.rallitek.com/products.asp?ID=352&ACC=Y I'm under the impression that the newer brake lines fit on the older subies, its just a matter of finding which ones you want, me, i'd go with the forester kit, cause i would assume that they would be the longest, which would work with the PK lift kit. But if the bandit with the third eye has them, i always like buying "local"
That first pic is now my wall paper, and a very convincing argument to move to seattle. I should know by friday if i have a job offer, if i don't i'm thinking a move to seattle is in order.
Hoopty, i believe the difference between your OBW and 97's is that his is actually his parents.
You are on the right track with the rear disc brakes, you might also try stainless steel lines, won't help with the stopping as much as improving brake feel dramatically. you may be able to find better brake pads, which would be the cheapest way of improving brake feel, "racing" pads will help a little.... if you can find them.
Yeah, but i believe it only has the RX low range, 1.19, not the 1.52 or whatever the N/A low range is.
Took her around the block today, she pulls like its going out of style, even with the swampers. got some relays and fuses set up so the offroad lights and the cooling fan should be working tomorrow. ran into a small problem, i don't seem to have power to the dash anymore, so nothing works. and the speedo head or cable is no good, i was keeping up with traffic in a 25 zone and it said i was turning 125 mph.
Has anyone ever tried this?
NoahDL88 replied to Subarian's topic in Old Gen.: 80's GL/DL/XT/Loyales...
watch your coolant temp, i had my belts a tooth off, and the temp went through the roof -
Tex's RX thread for November
NoahDL88 replied to Subarutex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Maybe your spark plug gap is too big, or your timing is too advanced? If its bogging it may be going uber rich, ,maybe dial back the rising rate fuel pressure dingus, or make sure that the stock one is good. -
you want the green connectos, at least the ones by your wiper motor to be apart for normal driving, if you plug them in the car will not be happy.
It does have an indicator, mine did, but when i swapped in the GL D/R transmission i just jumped the two wires so that the light was always on.
Most reliable Subaru engine?
NoahDL88 replied to SakoTGrimes's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Study up on the new stuff, the more you know the more you will learn to trust it, i'm sure you remember a day when adjusting the carb and setting the timing was intimidating. -
Those are your "V" belts, no timing required
the electronic parts are way more reliable then the carb and the old school ignition, sure there more expensive but they fail much less. i have 2 EJ powered cars, and now have a third, and the 2 that i've had running, have been running like champs with no interference for over a year, with the older motors, caps rotors and other items had to be replaced frequently. don't forget to add in the time working on the car into the money quotent, if it takes 4 hours to clean out a carb and re-install it, what does that cost you? -
for wheels you have 2 options, the 13 inch subie wheel, or any pugeout wheel off a 505 and a 504 model, the bolt patter you will be looking for is 140mm x 4 only the early subies and the 2 pug models had that pattern. Mcbrat in IA has some pug wheels for sale, 14 inch steelies, if you're looking to upgrade to a bigger wheel and or tire that would be the way to go.
while your in there, cam seals, oil pump seals and a new water pump are cheap insurance.
85 Carbed EA82 Wagon Cranks but wont Start
NoahDL88 replied to sregor13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
take the vacuume line off the disty and then set the base timing for what ever the car requires. 20 for spfi 8-12 iirc for carby models
