Everything posted by NoahDL88
Calling John Bloom (again)
NoahDL88 replied to NoahDL88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The car hasn't run well since i got the rack, trying about 3 projects at once, it was always a "i'll get it painted when the car runs" ........ so on that note, hopefully by october i'll get the chance to paint it. -
Who knows? Days and Counting (Edit First post)
NoahDL88 replied to NoahDL88's topic in Subaru Retrofitting
I'm using the Peugeot 14x6 wheel, i don't air down, but i've never popped a bead yet, knock wood.
Bah, thats a patina, it will raise the value of the rack in the future. -
A DOG, EPA estimates for an 81 subie is about 30 MPG, you should be doing better than 9
with the smallest BFG allterrain's they make on an 1980 with a 2.2, i regularly get around 26mpg highway.
I see why you guys from OZ/NZ do the disty swap, but here in the usa we don't have that option, unless we ship parts from you guys, which i'm sure as you know is probably more expensive then the part itself. However with offroad puddles, its nice to not have a disty to get filled with water. The swap is still on hiatus, still waiting for the adapter plate. argh. but it should be here this week, so depending on stuff i have to do this week, and when the plate gets here, she should be running by friday. Edited portion: Can you run the propane with the distributorless ignition, cause with gas prices the way they are that dosn't sound like such a bad idea here either.
Thats why i love the DL headlights, its almost a Delorean, i'm even thinking a Flux Capacitor may be in order.
Weak and ineffectual brakes......
NoahDL88 replied to bella's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Subies have a different order Front left Rear Right Front right Rear Left That is straight out of the 87 Factory service manual. -
once the car is warm, don't let it get too hot, run your hand from the bottom to the top of the radiator on both sides, if there are cold spots there are clogged spots.
Well, still no adapter plate. But i did get some work done. Can you hear me now? almost ready to go -
MAJOR brake problem... (after install)
NoahDL88 replied to Kostamojen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Jack the front of the car up, spin one wheel at a time and see if only one side makes a noise, then you've at least got it down to a side. Good luck -
the control arm would be my guess, it has 2 bolts on the lower suspension arm, and bolts to the body in the rear. I seem to bend those rather frequently offroad.
When my Ex-"pink-martini" bought her 88GL 2 years ago it had 24K on it
I think i figured out our discrepancy, between SPFI and Carby, the CAI may have opposite effects.
Maybe you guys do it differnt out west, but i want to reiterate my point, without the CAI, i ran into a lot more trouble in the water than i did with it. Best solution is to rotate it back, i'll see about a pic if i can get around to it
I had much worse luck after i remvoved the "snorkus" soaked the filter much easier. If you unscrew a few wire tiedowns you can rotate the entire intake tube, airbox and Maf into the spare tire area so it goes straight back. that will stop water under all but extreme circumstances.
SSR-02R 27x9.50R14LT Actual Diameter: 27.5 There radials so they don't get flat spots, this is on the 88, with the 3/3 Ozified lift.
Junkyard would have them, for about 3 years i had a Focus mirror on my drivers side glued to the broken Subie mirror, till my friend broke it off.
These are some decals i picked up from the dealership about 5 months ago. i'm pretty sure i have the entire "woodie" set, but i'm not sure. I do however have about 10-15 sets of the "rally stripe" some just say subaru, some say 5 speed and a few say 4wd.
