skins
Location
Moscow-Pullman
Vehicles
06 OBW
skins's Achievements
Member (2/11)
10
Coming from the Phoenix area it was really a necessity. I now live in the Seattle area. I am a big fan of tint and recommend it. I remember paying around $200 at the subaru dealership when i bought the car new a year ago. I recently purchased another car in the N.W. and the tint cost me $250 (had it done in Phoenix on a trip). Find a reputable tint shop that has a good track record. If you need to check the BBB. good luck!
My 06 OBW has just over 22,000 miles on it. Over the last three service trips to the subaru dealership they have noted that the tires are "cupping". they have tried to fix and adjust this with an alignment and rotation under warranty. The service manager claims that the tires must go because of severe cupping. He says that SOA will pay for 2 of the tires under warranty but I have to pay for the other two. Is this fair? Should they not pick up the cost of all 4?
After searching around for a bit i could not find an answer to my upgrade question. Let me compare this to a Land Rover since that is what I have worked with. If you want to add seat heaters in a Rover you purchase the seat heater switch, pop the plastic piece off your dash and install. instantly you have seat heaters, obviously they were pre-wired. You can do this with pretty much any accessory you want, fog lights, cruise, etc, etc. My question is can you do this with the newer impreza, I looking at buying a used 05-07. The possible upgrades that I would like to do are seat heaters, Auto dimming mirror with home link, and fog lights. Thanks in advance for your input.
Help with Carfax?
skins replied to skins's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks. It is clean..that is as clean as it can be for a used auto... -
I have done a little homework shopping for my next Subaru, but I wanted to get an outside opinion on price. A couple of dealers in Arizona have 05 OBW XT left over (premium package no navigation). If it is a clearance price what should it be? I know that list for the few I saw were between 33k-35k. Thanks
I take a different angle that the others on this issue. Alloy wheels microscopically crack over time. This can lead to the releasing of air through these cracks. If you have a shop that inflates tires with nitrogen have them fill it up. You may notice that the problem will go away. Costco (the wholesale store) uses nitrogen to inflate their tires in most areas. It is no secret that nitrogen is used in tires for NASCAR, airlines, and NASA. Larger molecule=no leak or slower leak......
I have a 98 Legacy GT wagon that had a tire blowout on the highway last week. In my reading I have found conflicting information on tire replacement. Some people say that you need to replace all four tires on an all wheel drive vehicle, and others say that you only need to replace two. Second, Subaru only recommends the tire size of p205 55R16 (H rated) is there another more common size that I could sub in the future? Any advice? Thanks
