njdixon4
Everything posted by njdixon4
  1. I'm not sure how the car is in the summertime (picked it up around Thanksgiving) so I don't know if it overheats when warm.
  2. By coolant return hose I mean the lower radiator hose. If I had heat but the gauge always read cold, I'd suspect the coolant temp gauge and if the engine warmed up but I had no heat, I'd say it was a blocked heater core, but the fact that I hav eboth problems baffles me.
  3. Alright, I got two issues with my '93 Loyale Wagon EA82. 1) This car never seems to warm up. It sits and idles and warms up a little but as soon as you start driving and/or turn the heat on, the temperature gauge goes back to Cold and it blows cold out the heater vents. The coolant return hose is cold to the touch as well. I have replaced the thermostat, removed the seized mechanical fan and blocked off the radiator with cardboard and still nothing. Anyone got any ideas? 2) After installing the thermostat, the upper radiator hose started leaking. The hose clamp was pretty rusty and I thought maybe when I removed the hose, the clamp cut into into it. So I replaced the hose and put an aviaton-style clamp on. But if you drive it, it still steams after you shut it down and you can see coolant leaking. Appears to be from the same area but I have the hose clamps good and tight on the hose.
