sregor13
About sregor13
- Birthday 07/13/1975
Contact Methods
AIM
happyrogers
MSN
gaberogers13@hotmail.com
Location
Lander
Interests
Working on Subaru's
Occupation
Reclamation Irrigation
Biography
Love Subaru's
sregor13's Achievements
Eat, Live, Breath Subaru (5/11)
10
I love the OEM Subaru Cargo bin. Took about 15 minutes to install. Looks great and adds a tons of storage. A buddy of mine who is 6'11" tall actually drives an Impreza. He has plenty of room for short trips. The issue for both of us is that after 600-700 miles the Car seems to shrink. The dealer in Salt Lake wanted the same amount for a used 2007 Impreza as the new 2010 model. I wonder why. What concessions were made to the newer models, that would drop the price 2-3 grand? The Impreza rules for parking in Denver. The car is so small that it can parallel park like nobody's business. A concern I have had, after getting in a head on collision, is the safety. Isn't the Legacy/Outback safer than the Impreza? If you have kids that is something to consider. Side airbags could be a real life saver.
Crutchfield. Just enter your cars info and select a Head unit for your car and note the part number in the shopping cart for the wiring harness. Then enter the year of the car you are getting a Factory Head unit from. Compare part numbers and your in. My two cents is that buying an aftermarket for the 96 is the way to go. I like the Sony's with the AUX in and or USB in. I takes about 30 minutes to install. Then you have options you know.
I have a 2007 Impreza Wagon 2.5i. It is way small if you are used to a Wagon (Legacy or Outback) You will miss the size, especially if you have passengers. In the rear you can have passengers if they are between the age of 0-7. A normal adult would fit but any kind of travel is a no-go. If the sedan is a 2.5 then I think 14,000 is to much for sure. If it has had the 30,000 mile service then that costs about $800. So make sure that has been done as it is pretty comprehensive. I would go no higher than 13,000, unless it is magical or has a Sunroof, Steering Wheel Audio Controls, Sat Radio and a high end stereo system. With that said if you are set on an Impreza then I like the 07 better then the 08,09 etc. However those should have the Sat Radio Antenna pre-installed (I think) mine did not. Also they dropped down in price in 08 I think. They started to look kind of like GEO Metro though. I also think they cut other corners. Keep in mind it is real small, not very powerful. My 96 feels much stronger. Not sure why but that's how it feels. My check engine light comes on regularly and the seat belt chime goes off even if you are in park in your driveway. Those two things are very annoying. I can disable the Seat Belt chime but I don't like to do that. I would mind it if it went off only when the car was in motion. When the Check Engine light is on the Criuse Control is disabled. Easy to reset by unhooking the Battery for about 5 Minutes. But once I do that the Seat Belt Chime starts up again. Its like a Catch 22 of BS. My buddy got a 04 Outback with 50,000 for about 14,000 cash. It a much more comfortable ride with heated Seats, plenty of room, and even Map Light up above. The cupdolder and center console is remarkable. I would not say the same for the Impreza. Its better to have one of those suits from Dune when traveling. In closing you feel every crack every rock and every little ridge on the road with those low profile 17" wheels. I enjoy my 86 GL much better for that kind of thing. So I gave the 07 to the nanny to drive. She was driving a 94 Legacy LS and really enjoyed it much more. The Impreza looks great and makes the driver look great but I would recommend a used Legacy for sure, unless you are just planning on driving in town by yourself and you are under 5'8" tall and weigh less than 165. Oh and did I mention it was small. That's my honest opinion but others may not agree.
Yes it is possible. We were able to pick up other people XM Radios. We had 2001 International 2-Ton. It had just a radio and no CD PLayer. I think we picked it up other vehicles FM Broadcast because we had a big style antenna you see on semi's. Better gain. As far as cell phones gp, most Handsfree Cell phone solution reqiure either wired or a Blue Tooth Connection. Bluetooth is 802.11 signal and I dont think anyone could pick it up a listen to calls. I am pretty sure you can add a WIRED connection to your Subaru with the Product made by PAC. This is a good solution for the Ipod. other than that I use the Monster Ipod adapter. It charges your Ipod and sends out the FM signal. Had pretty good results with it.
I pulled off the Rubber Boot and the plate appeared to be closing just fine. Then I cleaned it out as much as I could. Just to make sure it wasnt catching. Then I started it and the idle seemed normal. I drove it down the road and the idle seemed to find it's way back up. I changed the oil and starred at it for a good long time. Seems to be running okay but the CEL threw on after about 5 Miles. The air sounds like it is coming from below that throttle plate. I have checked everything and I can't find any place where it might be getting in. Perhaps the Gasket on the Throttle plate assembly? I dont know. But it does seem to idling fine at the moment.
In addition to checking the alternator and battery. Check all the wires that are on the Harness that plugs into the Alternator. When my wife was 6 Months pregnant our Legacy broke down. Corrosion on those wires had caused the car to outright die. It was about 10 Degrees outside and I had no tools. Thanks to her Makeup bag and a roll of black tape we got down the road. Check all the ground connections for corrosion. Make sure the battery terminals are not corroded. Might be a good time to replace them. Seems like every Subaru I have has had a problem keeping a good connection resulting in the battery going dead. Most Auto shops can test the alternator. I am not sure the test is all inclusive though. I have had alternators test good but once I put them back on the car the Voltage Regulator in them goes wacky. So if there is an intermittent problem with the internal Votage regulator, the test may not show it. Either that or the guys at my Auto Parts store don't know how to run the machine. I bought a Black and Decker battery charger at Wal-Mart that does battery desulfation and Alternator test. B&D bought Vector which were the only cheap battery desulfators I could find. Between that feature and all of its diagnostic features it paid for itself in a matter of days. Good luck.
Correction, when I plug the tube or the hole on the IAC it does drop the idle. Also if I unplug the MAF Sensor it also drops the idle. I have changed out the IAC and the mass air flow sensor. Still the same. Super high idle. My hands are covered in dirt and grime and we are having a great time working on this. Just firing up the Bar-bq and we are going to really get into this. Thanks,g
Okay put the timing belt on again and made sure that it was just right. Still the Car idles really high, like its redlined! Anyway tried the IAC test as suggested. The idle didn't go any lower and the car didnt stall. So air must be getting in elswhere. Or could it be the Crank angle sensor? I replaced it before becasue the car wouldn't start. Maybe its not right. Also I ordered a ODB2 Scanner and it should be here in 7-10 Days. Problem is that I need the car running sooner. Any ideas? Thanks
Also the Vaccum lines and all look good except the Cannister that has all the charcoal stuff in it is a little brocken. The IAC is connected but I am not sure if it works. I guess the surging was something that happened after my friend adjusted the TPS. Before that it was just High Idle. I mean really high.
