About PAezb
- Birthday 01/01/1960
Contact Methods
Website URL
http://
Location
USA
Vehicles
96 OBW, 05 OBW XT
PAezb's Achievements
Subaru Fanatic! (6/11)
10
I'm replacing both rear springs and struts on the 05 OBW at 95K, but I have done a lot of towing so the rear suspension is starting to get soft. As mentioned above, how the car has been used and driven will play into when the components need to be replaced. Subaru OEM struts - $89/ea springs - $34/ea from Jason at Mike Scarff Subaru. I should mention that I still running on the originals on the 96 OBW - 263K miles! They're soft too, but *not too* bouncy, and I perfer the ride compared to way it rode when it was youngster.
Dont mean to hijack this thread but I thought since this is on the subject of car batteries I'd like to make a product recommendation for a battery charger. Just purchased one of these in an attempt to bring back to life a Interstate SRM 29 deep cycle battery that is used in an RV trailer (I carelessly forgot to pull it out for storage for the winter and it discharged and semi-froze:eek:) Another brand charger that shall remain nameless could not do the job. I've only used it for this one battery so far. Thought I'd have to replace the battery, but this charger's rejuvination and equalization features brought it back to life. Highly recommended based on the above: http://www.pacificbattery.com/schauer_cm16a_charger.html
Yep, try disconnecting the battery for a few minutes (hit the flashers switch and step on the brake pedal to drain all energy from the system) If that doesn't work, when you can, take it to a DIY carwash and wash around the inner wheels - may have snow, ice, dirt, or other debris interferring with one of the wheel sensors. If that doesn't work, you may need to check for sensor, tonering, or wiring damage. Lastly, the ABS will often come on when the battery voltage is low and the alternator is failing. Is the battery icon in the instrutment display also lit?
You can always tip the entire car on it's nose/side Good advice though. Also, remember to use new crush washers when putting the drain/fill plugs back in. I've done the diffs on the 96 OBW twice now, the first time at 100K, I remember the plugs needing some extra force - a 30inch pipe over the handle of a 1/2 drive. Had to use some force but they finally did break free. On the newer MY05 to date the plugs now require Hex and torx drives - make sure to buy good quality ones....
Yeah, it is coincidence, the boot is actually ripped all the way around (see pic attachment). I have bought the front axles from MWE for the 96 Outback, so I am familiar with them - it is an option. I just figured under a 100K on an XT I may want to go with a new Subaru OE. I'm having a dealer do the t-belt and plugs anyway so I'll them do the boot or axle. If you were in the area I'd ask you if you would do the entire job
Being it's Motor Trend's 2009 Sport Utility Of The Year speaks to, at least in part, to why Subaru sales are up when every other manufacturer is down. I still would wait for 2010 and see if the Turbo Diesel will be available. Wonder if the vehicle frame, brakes, suspension will indeed be designed to match the towing capacity of the engine (from a 2.0 4 banger - amazing!) http://www.motortrend.com/oftheyear/suv/112_0812_2009_subaru_forester_suv_of_the_year/index.html
Something else I'd like to share, slightly off topic. I'm also planning to finally put in the transmission cooler on this car as I tow alot. What I discovered in looking for the fluild lines is that Subaru has now routed the fluid through a independent filter that sits *in* the front driver-side fender, behind where the battery sits. In the attachment, you are looking at the empty battery compartment and you can see the filter in the top back of the pic, with the writting on it. Now this makes accessing the line very easy to install the cooler, but it isn't it odd to place the filter in the fender? I mean, what if even a small fender bender were to occur in that area? Poor design IMO:rolleyes:
If you think thats insane, I'm getting ready to do the T-belt and spark plug replacement, a local Subaru dealer here in the Twin Cities, whom will remain nameless for now, gave me a written estimate on parts and labor. Just for the parts, the belt alone is $175 and the iridium plugs are $30 each:eek: Jason's prices are more reasonable: 13028AA240 t-belt $110.66 22401AA670 spark plugs $11.77ea Damn local dealer labor rates are getting outragous too - $115/hr:-\
Well, I began noticing a oil burning smell on a trip awhile back on my 05 OBW-XT. I have had some trouble with the purolator oil filters leaking around the seal under pressure in the past, and this was just after I change the oil so I figured that was most likely the problem. Hadn't been a big deal as the body of the filters when they did leak was very minor. However, I finally did an inspection and found that the smell was coming from grease splattered on the front CAT from a split in the drive boot right in front of it. Now, I have probably put a couple of thousand miles since I first noticed the smell. Contacting Jason at Scarff Subaru, he thinks that all I will need is the boot/grease kit to replace instead of purchasing a whole new drive axle. My concern is the amount of time and contamination that has occurred to the CV, figuring it's safer to just replace the whole axle. Price is $300 for the axle vs. $66 for a new boot and grease. The car has about 93K on her. Opinions welcome.
I've always been statisfied with my purchases at etrailer.com: http://www.etrailer.com/products.asp?category=hitch&year=2001&make=Subaru&model=Legacy&t1=&h=e&style=Outback+Wagon&ob=&so= Keep in mind the total tow weight and tongue weight - with emphasis on the later. I'd be leary to tow that much weight without a secondary brake system to assist (i.e. trailer brakes - requiring the installation of a brake controller in the vehicle). Renting or borrowing a truck for this single purpose may be the way to go.
When placing a parts order with Jason at Mike Scarff Subaru last summer I had asked him about any problems with the 2005+ Turbos - he mentioned that he had seen a couple come in destroyed - apparantly due to dirty filter mechanism on the turbo from not changing the oil regularly (3700 miles Subaru requires). I guess small contaminants can starve or mess up that precision bearing in the turbo:-\ Turbo owners, make sure to stay on the maintenance schedule....
