3
Everything posted by nick1208
hopefully I'll see you there!
Anyone got the measurements for a loyale bumper or blueprints or one they could measure for me? Wanting to fab one up and wanting to know how much steel to get, and where to cut it. Thanks.
Yeah I'm fine. Lucky it wasn't when I was on the freeway about an hour prior.
Learned a valuable lesson today! always put your car back together the right way! ball joint nut came off while driving, ugliest noise I've ever heard. aftermarket arm so there is no hole for a coder pin. My dad ran to the hardware store while my car sat like this and got me a nylon lock so hopefully it won't happen again. Not related to my "build" but felt the need to share.
really clean looking skid plate!
Lots of progress this weekend! Got the dual range in! here's a shot before install. both trannies side by side. dual range on the left. interior shot. I didn't have to lengthen any linkages, but it does have a rough time going from 4-HI to FWD. Have to get under the car and pry it in. Anyone experienced similar problems? Might have to lengthen the linkage a little? Happy car!
Thanks! I assume you mean offset? All I can tell you is the wheels are off an old Ford courier and I'm running 27x8.5x14 tires. Let me know if you want me to measure anything specifically.
94 Loyale won't idle well
nick1208 replied to nick1208's topic in Old Gen.: 80's GL/DL/XT/Loyales...
should be fixed now. -
That sound might be the intake manifold leak my dad pointed out. -
Here is a video. http://www.youtube.com/watch?v=-fQauBEJL84&list=UUYAIL-hfwQyLKZWIOGZSZ6Q it does sound like one of the hoses is cracked -
I've just recently been experiencing problems after an offroad trip. Looking for what the source could be. At idle occasionally it will hold idle at around 1,000 rpm (not unusual for my car, which usually idles around 800). But sometimes it will sound like its bogging down and jump down to 200-300rpm and i will have to give it some gas to prevent it from not killing itself. The only thing that i've done to arouse any problems recently is the offroad trip and take my muffler off. I got home today and opened up my hood and I heard some hissing off and on. Could it be a hose leak that's causing problems?
Found a junkyard car that had something I wanted so we popped it out and took it home
I had to make my car cooler
working on it. I had a decent amount of money saved up then I met Marcus....
Here's a recent shot by a friend of mine after the Tahuya trip. The mud looks yellow but the more I look at it, the more I like it. plans to get a light system going on the front of the basket are in works.
It's great! some of my friends at school have them and every day I pull in we get on the CB and shoot some spoob over it. Also at Tahuya the past week I used it quite a bit, its nice when almost everyone in the group has one. It makes life much easier.
good place to hide wires from lights on my basket?
nick1208 replied to 92loyale59's topic in Off Road
wow hard to believe i run the same size tire. How much did those run you? im looking for new tires. -
I want to do something similar but the rack i have is too small to drill through. sweet ride! how big are those tires? anything from closer so i could see how they are mounted? -
Here I'll put up the pics I took. The blocks we lifted it on for installing. Barely big enough. dropped the engine on rubber! how marcus has to work on his car now. Or he could get stilts?
Curious as to how you mounted the lights on your basket. My frame of the basket is too thin to drill through and fit the bolt. Pictures of how you or others mounted ? -
Cb radio installed today. Here's the antenna. A picture of the mount i put on for the mic. CB mounted on a bracket for the tray below the radio. Full interior shot
So i clicked my car into 4WD and i heard funny noises on the way home in 2wd. Checked it out. I guess the bolts came off the mustache bar to hold my diff up!?!? It's wedged under at this crazy angle and I can't kick it out. I don't have any jack stands so i don't feel comfortable kicking at it while its lifted. I guess i'll see what I can do tomorrow. Anyone had this happen before?
Looks sweet! Always loved GT wagons.
