2
Everything posted by Flowmastered87GL
cool performance place in Salem, OR
Flowmastered87GL replied to JonOfScio's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sweet, I may have to go there when I find a donor carb to install in the BRAT -
1987 Hatchback Gl (Any body conversions?)
Flowmastered87GL replied to dem0nk1d's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Regarding performance exhausts I run a 2.0 to a cat, 2.25 to a flowmaster delta flow 40 series to a 2.5 tip. No rice tip here -
1986 GL-10 rear axles into GL???
Flowmastered87GL replied to playswithfire's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ummm try tightening the rear axle nuts. I had an 88 Gl wagon and it turned out that the right rear axle nut was loose. The rear suspensions tend to squeak alot after 200K it seems. (I swear mine has no bushings left) Where about are you in the valley?? There are alot of us in portland area and albany area too. Beaverton OR here -
Difference in 85/86 and 87-up fenders?
Flowmastered87GL replied to TROGDOR!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
OR that 84 wagon was an 85 that was made in 11/84 or something The trim IS different (the 85-86 stuff is not as tall) -
Portland Rally-X Results are Up
Flowmastered87GL replied to 84SOOB's topic in Meet n' Greet. Your USMB Welcome Center
The Durango may have beat Luke, but Eric beat the Durango I got 7th place for the season in Truck/SUV cause I only got the MPV thing going for me for the last 2 events -
Please read (all)
Flowmastered87GL replied to PHATBRAT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably the person who never sent my cargo cover :madder: Come to think of it... I have not yet received my subaru owners do it on all 4 sticker :cornfuzz: (not saying that one is a rip though) If we did have a rating system... whats to keep a person from making extra accounts and making fake purchases from themselves to rack it up?? The word of mouth and experience works very well I think. People who have earned a very good reputation in my book: Edrach DrRX HondaSucks Caboobaroo BajaVWScoobnut Skip RichieRich I'm sure ive completed business with more people, but those 7 always came through with my money or parts or labor. And Andrew has had to come up with over $1800 over the past year Not sure how much ive sent his way... over $2000 im sure -
It was the positive terminal on the starter... thats why jumper cables wouldnt help at all
Ok your car has 112K on it and the cable broke.... ummmm well think about it... most cars in the junkyard will probably have 50K more than your car... could you really trust that cable?? Its worth it to get a genuine subaru one... maybe use a junkyard one til the suby one comes in.... but get a new subaru one
Any photos of rallyX 10/12/03?
Flowmastered87GL replied to ezapar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The white EA81 wagon belongs to GLCraigGT, the Gen 1 BRAT belongs to a new member luker I believe is the name he is using, the white EA82 wagon is Andrews, the Forester is Jasons, the hatch is Zaps, the silver wagon is mine the brown DL brat is Eric Rachners, the black brat is Johns, the red EA82 wagon is a friend of Johns (160HP or so ), the blue 76 is jasons, the blue hatch is kens and of course the RX is yours Mark Ummm I think that covered all of them -
I see my car in the pits... thats good enough for me.... its a pretty good picture -
ea81 weber conversion
Flowmastered87GL replied to lukr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Luke... its mike with the silver 87 wagon at the rallycross.... got an extra weber you want to sell to me for my 82 BRAT?? I already have the adapter and I am going to have it rebuilt... I am looking for a 32/36 with electric choke. Hmmmm it wont let me PM you for some reason... So please e-mail me at the_great_mikeholio@yahoo.com -
Any of my GL?? -
left and right ea82 heads same?
Flowmastered87GL replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya, other than the EGR I belive they are identical.... I know for a fact that the head gaskets are identical on SPFI's -
$#&^%$@%!!!!!!! Ahhhhhh!!!!
Flowmastered87GL replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there should be pushrods in there.... remember that crate of stuff I got from SubaruSyndrome Andrew?? I belive it had a pushrod or 2 in it -
I suggest removing the pedal from the mount... its alot easier to attach the cable to it that way. The hardest part in my mind was to get the 2 bolts on the mount for the cable in place... 1 is easy 1 is hard. The cable is only like $17 so it will take you 1.5 hours tops hopefully and be reasonably cheap
I tension mine too.... the torque you are supposed to apply varies... on my 88 I had to do 17 lbs or so because it had new belts AND head gaskets.... otherwise 12 sounds about right. Supposibly if you dont tension them they are more prone to eat teeth like my 86 turbowagon did... those belts were NOT pretty when they came out of that engine
Timing Belt Deal Question
Flowmastered87GL replied to penncrude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok.... first to go on is the drivers belt. So put the flywheel in the middle of the 3 marks with no numbers on them. Then start the belt on the crank, then go down to the oil pump, then to the idler, then up to the cam. The cam should have the little dot on it pointing UP. When the belt is fully on make sure everything is still lined up, then let the tensioner make contact with the belt. Torque the belt from the cam pully somewhere between 12 and 18 lbs (depending on belt condition i belive) and then tighten the tensioner whereever its sitting. Then turn the crank 360 degrees. Now do the same on the passenger side... start from the crank, go to the cam (dot pointing up) then back.... do the same preloading on the belt here. As a reference when doing the passenger side, the driver side dot on the cam will now be pointing DOWN... that means you are doing it right
