2
Everything posted by Flowmastered87GL
Flowmastered87GL replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That red wagon with the roof rack is hot -
2 questions... 86 GL
Flowmastered87GL replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya its the vacuum for the HVAC controls -
Ben's been in an accident
Flowmastered87GL replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can pretty much guarantee that will be totaled, my GL took a hit WAY more mild than that and they said it was $1200 in damage and totaled it out. I swapped the front bumper, kicked the fender (it just had a tiny bow to it that the kick fixed) and was back on the road for like $75 including title stuff. Oh and this was back in 2004 or so. -
Ya... I loved my EA82... but I swear I put almost $7000 into it to get only 100K miles out of it. I am FAR less than that into my Baja.
My 1993 Loyale: Work In Progress
Flowmastered87GL replied to GirlWithALegacy's topic in Members Rides
To do the oil pump, yes the timing belts must come off. To do the WATER pump, no. -
Free EA82 Timming belt install Instructions
Flowmastered87GL replied to Rust's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good they have the most critical step on there (that some manuals miss) Do the drivers side belt with the cam mark pointing up. Then turn the engine 360 degrees, then do the passenger side with cam pointing up. Some manuals neglect to say to turn the engine over once. -
Weber carb for my 87 gl?
Flowmastered87GL replied to Moosen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I went to the auto parts store and just bought vacuum plugs. They are just little rubber caps. The vacuum keeps em on. But make sure they are a snug fit. -
Once you weber it you will ditch most of the hoses. You can see the vacuum line to the HVAC controls and the PCV lines and not much else in the pic. No more EGR or Evaporation canister. (this is my car at WCSS 5) -
Can I repaint my lisence plates?
Flowmastered87GL replied to NWSubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If they look the same... just paint them.... it may be tough to find a shop willing to do it, but if you don't change the number and restore their legibility... go for it yourself. -
You know you have been here a long time if you know who owned that car (and the fate of it) Answer: If I recall its The Subaru Junkies car (Brian) And I THINK this is the one that got towed away?? (or its replacement) -
Calmasters are the shiznit Look at that body roll Yes this is me around the era of WCSS3 or so. -
Look at all the subies down under
Flowmastered87GL replied to subinewby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ha ha that song is awesome "So I sitting at a traffic right" -
Presenting Leo, a 78 Brat in Portland!
Flowmastered87GL replied to DatSub's topic in Meet n' Greet. Your USMB Welcome Center
I'm game.... I live a few blocks away from the Rogue Ale house on NW 14th and Flanders:D I agree that both the 510 and the Brat are pimp -
Opinion on Headgaskets
Flowmastered87GL replied to wentz912's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I pull the engine personally... in my opinion if you know the engine in your car is otherwise good, I would pull it, reseal it and put it back in. If you find something bad (like metal in the oil pan) then fall back on the friends engine. Of course make sure you do both head gaskets even if only one is leaking. -
Funky blinker, cut out, tach bounce
Flowmastered87GL replied to seanjenn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It wouldn't hurt to have the alternator tested too... make sure its putting out enough juice. My tach bounced in my GL when the alternator was on its way out (though not with any involvement from the signal) But still... most parts stores will test it free. -
I saw one of these woody EA82's in person WAY back about 10 years ago in a wrecking yard.... I never thought I would see another one -
Wow look at that black XT -
How easy is it to bust into an EA82?
Keep a mileage log somewhere inside... like on your computer. Unless they pull the speedo cable you will know pretty quick. -
You likely have tried it, but since you did not mention it.... did you check your fuses??
how to deice a window
Flowmastered87GL replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ha, I assume the window was rolled down and the ice remained... so it was chuck norris'ed out. -
Winter Wonder BRAT!
Flowmastered87GL replied to BratWarrior's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ha ha, I laughed at that snowman in the jumpseat. Thats the best idea EVER! -
My Baja is torqued to 89 pounds of torque (I had been doing 90 and Costco spec'ed 89 when they did my tires so thats where I do it now) However its not a GL.
CLUTCH pedal just came off?! '87 GL
I suppose its possible that the little pin that holds on the clutch cable sheared, but I more likely suspect the cable. Mine broke on my GL (back when I had it) 7+ years ago. so age-wise yours is overdue if its original. You can always take the clutch pedal off its pivot (remove the nut from the end and it slides off) to get a better look. Crawling under the dash is not fun. I think it took me around an hour to install my cable (Get a new one if its indeed the cable broken) (as oppsed to a junkyard one which may break any day) -
PDX Alignment Shop?
Flowmastered87GL replied to kayakertom's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I took my Baja to Firestone in Vancouver and had "hondasucks" (his real name is Andrew) do a lifetime alignment on it. Its near SR500 and Andresen.
