drquasievil
Contact Methods
Website URL
http://
Location
Somewhere over the rainbow
drquasievil's Achievements
Advanced Member (3/11)
10
I have the same model and year and I had to replace it too and it was hard to take out. Use a cloth so that if the bulb breaks in your fingers you don't get hurt. I don't remember of it's a push in and twist to get it out or just yank it out type. find out which type of bulb it is, go to a part store and purchase one and you'll see what needs to be done.
Since everyone is ***************ing, I might as well do to. I use headlights a lot, They shut with the engine so I keep them on. They are not as I have found, daylight running lights. After a few years, I went for inspection and the mechanic told me I needed a bulb, So no choice but to say OK. Two weeks later, The bulb went again, so this time, I bought one only to find out the mechanic didn't change the bulb, it was the connector. Got screwed ( I guess he did since he lost a customer for $14.00). Anyway. both connectors were fried from the heat. I called Subaru and was informed that I needed to replaced the entire assembly at a cost of approximately $400.00. The coglione on the Subaru parts department to quote me that price. So I did what McGuyver would have done, strip the wire, attach it to the bulb, and wrap it.
tribecca
drquasievil replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That ugly mofo needs more than a little nose job. This is what I would do with that body ---------------> -
95 Legacy 90K Miles I had Subaru replace the timing belt and water pump at 70K miles, about 4 years ago. I noticed antifreeze leaking from the timing belt cover. I can't believe that the water pump needs to be replaced again. Do you think it wasn't replaced and charged me for it? Is there a way to tell if it's the original? Also, I need to take it for repair, The drip starts almost immediately after I start the car, can it be driven about 5 miles?
Today I saw a brownies pulling a fairly new Outback sedan. For those not from NYC, brownies are those who work for the city of NY, give tickets and tow anthyng on wheels parked illegally. She had the front of the Sub up and waiting at the light. I was going to let it go thinking maybe she placed the fuse in and disabled the AWD. But then again, I figure she is a brownie I better tell her that she was pulling an AWD and was going to damage it. So I did, she looked at me, said OK, and drove off. I guess I knew that she was going to ignore me. When she drove off only the back wheels were turning.
