mightGETaSUBARU
Everything posted by mightGETaSUBARU
I totally agree... I told him(Johnny) buy NGK plugs and the worthless parts jokey sold him Autolites... I told him get NGK plugs they just plain work...He thinks the guy at Autozone is a doctor... I explained to him... The doctor is the mechanic who works on your car, he prescribes parts for the repair and makes the repair (I was a mechanic for a well known Porsche repair and performance shop) the pharmacist is the autoparts store's computer... and it aint always right, the pharmacist's assistant is the worthless parts jokey... who likely knows nothing about diagnosis
I have a higher mileage 1998 Legacy Outback (2.5DOHC)that has about 313,500 miles on the clock... it used to be mine, but I have recently gifted it to a friend Valve covers where leaking like a sift... so I changed them It ran smoothly before this, nice crisp throttle response. The new owner purchased Autolite Platinum AP3924... I checked the gap, looked good, I know you should not adjust the gap on platinum plugs.... But I still carefully check them, I have found a bad one once before I typically run NGK BKR5E11 I did not replace the wires as the car was running fine at the time it's a slight stutter off the line, seems fine as the car gets past the blip, it also seems to buck a little bit if you blip the throttle while parked...
I have put a lot of miles on my 1998 Outback... it at 313,000 as of a few days ago. The weird thing is from time to time the speedometer won't work... and sometimes when that happens the transmission won't shift past 1st gear. Normally hitting the gauge cluster will cause the Speedometer to start working...(sometimes it won't help) normally this will cause the transmission to hunt for its gear (engine revs until it shifts) then it runs fine... This has been going on for about the last 115,000 miles Ideas please?
Auto trans I did try neutral if the contacts are worn out wouldn't it give some early warning like slow starts? It does not even click at all, it's like the starter is not even there electrically I am heading back out to the church today armed with a test light, a 10 gauge jumper wire, digital volt/ohm meter, and at the bare minimum that should get me home another thing I noticed is a few weeks ago the key I usually use kept getting stuck in the ignition, I also noticed that the ignition switch felt a little wobbley however my spare key does not get stuck so I doubt it is related... is there a FUSE for the starter?
so I got out of church tonight (yes it's friday night) and the Subaru would not start... it would not turn over at all I can hear the fuel pump, hear a relay on the passenger side kick panel area, the voltage is about 12.5 and does not drop when the key is turned Any ways I need to figure this out... is there a relay or fuse associated with the starter?
ok so I have a parts wagon, an 1996 legacy wagon with a working 5spd manual... nice nearly new WRX lowering struts and springs... also has a 300 HP built up 2.2 turbo... however I don't get the engine, its going into my friend's 1968 Porsche 912, wide body and whale tail... anyways, I release he trans and other stuff will just bolt up, BUT what about the ECU? throwing codes, ect... is it possible to make the auto ECU play nice with a manual trans?
I actually have a post up with the symptoms, anyways it all started after a head gasket job, I had disconnected all the main plugs, ecu to engine erractic shift points, maxing out fuel rims, rough idle, however about 2000 miles ago I reconnected the fuel pressure regulator, in the process I bumped the harness plugs and it ran great for about 2000 miles... now its doing it again, the fact that is started working when I happened to jostle the harness tells me something happened there
ok I need some help, I am loosing my mind here, I can no afford all the extra fuel costs, and I can not afford to take the car in I replaced the front o2 sensor, but it did not help so here is my QUESTION: What can cause ALL these problems??? erratic shift points and shift 'hardness' or softness (automatic) stutters at idle maxed out fuel trims fluttering/rough idle 12-15 mpg no codes at other times running just fine, with mid 20s on fuel mileage and smooth shifting my gut is now telling me the ecu/engine harness is buggered up some how.
