InquiringMind4u
About InquiringMind4u
  • Birthday 01/29/1973
  • Location
    Grants Pass, OR
  • Referral
    Google
  • Biography
    My girlfriend drives a 1996 Subaru Legacy and I need a little help with some problems it's having.
  • Vehicles
    1996 Subaru Legacy
InquiringMind4u's Achievements
Newbie
Newbie (1/11)
0
  1. grossgary - thanks for the quick reply. Forgot to mention that I checked the throttle linkage, and all was well. Nice to know the computers are reliable - and cheap. That's a relief. Tim
  2. The Car: 1996 Subaru Legacy. Standard engine with automatic transmission. The Problem (s): Last week, upon start-up early in the morning (it was very cold here is southern oregon), the car did something really weird for my girlfriend. Here's the text I got from her: "I started her up, she was fine. Put her in reverse, still fine. Hit the gas, nothing. Wouldn't accelerate or even sound like she wanted to. The engine didn't rev at all. All the lights on the dash came on like she was throwing a fit. Turned her off and restarted her, and everything worked fine." Something else that's likely related: The check engine light came on a few days earlier (see details below) and when I hook up my ScanGauge II to the computer, it reports "No Error Codes Found." Also strange is that when the ScanGauge is hooked up while driving, it seems to get intermittent feedback from the computer. At times the values just freeze. At other times the gauge seems to shut down because it's not getting any signal. I hooked the gauge up to my Toyota RAV4 (2008) and it registers and displays real-time values perfectly, without the intermittent display issues seen on the Subaru. The check engine light was on for about 5 days. During that time the car's idle was rough/low, the transmission seemed to shift at higher than normal RPMs (automatic), and all-around performance seemed a little rough. But one morning the light didn't come on, and the car has been running much better. Possibly an intermittent ground somewhere? Background: The water pump seized a few weeks ago when she was driving it home from a ski trip. The car overheated, all the coolant drained out, and she drove it for maybe a minute or two after the temperature gauge dropped (from no coolant) before pulling over and turning it off. Since I had to disassemble the timing belt & idlers to change the water pump, I replaced them at the same time. When I did the repair, I removed the radiator, which meant disconnecting the transmission cooling lines. When I put it back together I had to top off the transmission level. A day or two after I topped off the transmission fluid, a check engine light came on. I hooked up my ScanGauge II but it gave no failure code. Any idea why it threw that fit the other morning? Please don't say the computer is dying! Just thought I'd ask in case it's a well-known failure / trouble indicator. Thanks, Tim
