Tremmor
Everything posted by Tremmor
Loyale wagon 4x4 rust repair
Tremmor replied to Tremmor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does that strut mount with bolt holes come off along with strut tower once i remove remaining spot welds next to green line or do i need to separate bracket and tower? Drilling those welds aint too bad, much more fun than drilling broken bolt out. =) http://imgur.com/Id2PnBu- 7 replies
- rust
- wheelwells
(and 2 more)
Tagged with:
Removed covers from passenger side and it looks like its been repaired before with wheelwell from donor car? Lower part felt like it was held together with seam sealer or glue, and top has holes that might be drilled spot weld? Last picture is driver side crossmember end. Do I have to weld bar from side to side to stiffen chassis if I remove strut tower from one side, like its too flimsy? http://imgur.com/a/qv376- 7 replies
- rust
- wheelwells
(and 2 more)
Tagged with:
What tools and spare parts do you guys carry?
Tremmor replied to stratman977's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wood blocks if you need to lift car up in soft terrain for extra support for that little lift thingy, gas, matches, flashlight, roll of tp, something to eat & drink, knife, axe, long rope, high visibility vest, cell phone & battery charger, smart phone/laptop, your favorite mixed tape of AC/DC & Haddaway to play while fixing car & posting into "What Have You Done to your Soobie Lately?"-thread. =) -
Howdy gents, this is a classic example of: how to pour money and time into car and find out later that it so rusted its not economical to have it fixed by professional but you cant back off anymore. I had my Loyale pre-inspected to find out if it would pass/fail tests, I thought it might need carb adjustment and maybe new valve cover gasket and thats it. Mechanic poked around with hammer and results were that both rear wheelwells are crumbling. Rear crossmember is a mess and he said thats not allowed to be welded and needs to be replaced. Also strut tower is compromised. Problems are on both sides off course. Planning to replace rocker panels as well. Would be a good idea to drill spot welds in strut tower to remove it and do the welding at bench? I'd imagine it would lead to better results than doing via wheelwell & trunk even thou its seems more troublesome. Any dos or donts in this matter? http://imgur.com/a/VASst
- 7 replies
- rust
- wheelwells
(and 2 more)
Tagged with:
It just popped in my mind since I had one in a tractor, its flexible, bigger area for grounding and holes for bolts & nuts/screw. If you go with crimping connectors, protect it with dielectric grease and electric tape so it doesnt oxidice so easily. https://dlnmh9ip6v2uc.cloudfront.net/assets/9/1/8/9/9/5138de3bce395f591d000000.JPG
Thank you for explanation! I found numerous tire size calculators and http://www.miata.net/garage/tirecalc.html is one of them. Would this 3.2% size difference be too much? I think it might be actually more than that if tread is more worn as these are older tires, gonna check missing spikes as well. Tire Size Comparison metric Specification Sidewall Radius Diameter Circumference Revs/km Difference165/80-13 132mm 297mm 594mm 1867mm 536 0.0%175/70-13 122mm 288mm 575mm 1807mm 553 -3.2% inches Specification Sidewall Radius Diameter Circumference Revs/Mile Difference165/80-13 5.2in 11.7in 23.4in 73.5in 862 0.0%175/70-13 4.8in 11.3in 22.6in 71.1in 891 -3.2%
Float level on 83 subaru GL
Tremmor replied to peterelliott05's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In case you remove jets use right sized screwdriver, you might have to grind them to make them fit as brass strips easily (dont ask how i know that) -
if you have Hitachi carb (i have) you can take top out for float level adjusting but i'd take whole thing out for cleaning. -
Before starting to remove transmission we decided to inspect clutchdisc and flywheel; 3 flywheel bolts were backing off and one was so much out it made contact with clutch disc causing those sounds and abnormal shifting experience. I remember torquing them to 75 newton meters (55 foot pounds) and I'm pretty sure there was no thread locker involved as manual didnt mention it if I remember correctly. This time I used it and after engine was reinstalled it shifts perfectly all gears without nasty sounds. I love Subarus, they are so forgiving. Thank you for your help and interest. http://oi57.tinypic.com/2z4ivwh.jpg edit:flywheel bolt picture added
Thanks Gloyale! Easy front seal replacement thread is excellent and looks doable so contected subaru dealer about seal and bearings but unfortunately no oil seal available and bearings aint stocked at importer so order takes too long for my taste. Best to remove transmission and get serial number to be sure I get bolt on used replacement if things go that way and peek inside to see if theres anything alarming. It's 5 speed dual range transmission and opposedforces part numbers don't bear fruit in ebay wise, except for oil seal.
Update: motor is removed and can't detect problems with throwout bearing as it turns smoothly and quietly, much smoother than old one. Clips holding it were also ok. Pressure plate looked ok. Dial indicator measures 0,8mm (0.031") side to side play on input shaft, it seems quite a lot. All gears but reverse shift smoothly and that one needs a little more determination. Also turning input shaft by hand (gear in neutral) is ok. Do I jack car up and try turning with gear in with tires off ground to see if it makes any difference? Unfortunately this great and awesome idea came now and not an hour ago while I was in garage http://oi58.tinypic.com/2eq9xrq.jpg What would be next logical step (besides buying newer Subary, one with turbo)?
Hi! I replaced clutch maybe max 1200 miles ~ 2000kms ago, a hair less than 300000 km (186k miles) in odometer and today when I was driving back home I noticed when i was shifting into smaller gear it kinda threw off from bigger gear, it was probably from 4th to 3rd gear. That might have been happened twice earlier and it mostly felt in hand, no odd sounds or nothing. This time it was different, when making more gear changes it felt that something aint right at all and I turned radio and fan off, it was harder to change gears and noise came into cabin so i parked and checked if clutch cable is to blame. Well adjusting it didnt help a bit. If gear is in neutral it idles without additional sounds but after putting any gear it makes noise. Next video is taken when putting gear on for while. Sorry this is so vague description about problem, towing it to garage tomorrow morning and hoping its something simpler and faster than removing engine and redoing clutch. http://tinypic.com/r/1zftm6b/8
Update: on the way to home I noticed nasty sound coming from front of the car it was like something was loose. Gear in neutral pressed gas pedal and noise got louder, but it was still there when car was idling. Then I noticed that pressing clutch pedal made noise quieter, turned clutch cable adjustment screws few turns tighter and sound went away. Either those screws need some thread locker or some glue type thingy to prevent vibration to loosen them or clutchdisc got broken in maybe, I dont know. Anyway, time for short test drive to verify theory.
Tried to measure spark plug wire resistance for cylinder #1 and found no continuity nor resistance with multimeter so I ordered new plug wire set. Spark plug testlight shows spark in all plugs. I couldnt get resistance even for coil pack posts (Diamond F-569) when testing it even after using contact spray and light scuffing with sandpaper. So it seems kilovolts jump over two gaps or more for cylinder # and minimum of 1 gap for others. Does coil pack ground itself with 4 bolts to intake manifold? Underside of coil pack had paint flaking off around bolt holes. How long lifespan do coil pack have anyway? Wonder if it would be safe to get one from wrecking yard or get new one that is.
- 10 replies
- sensor
- oscilloscope
(and 1 more)
Tagged with:
Got more logical results by connecting black wire and actual ground, at least scale was 1V, but it was pretty much straight line even if engine was warm at idle, if i revved a bit voltage got to 560mV but nothing to describe as smooth swinging so guess its time for new sensor.
- 10 replies
- sensor
- oscilloscope
(and 1 more)
Tagged with:
Either of two whites and black wire gave that 35V. Lets see if I get same results today =)
- 10 replies
- sensor
- oscilloscope
(and 1 more)
Tagged with:
Had to verify if I was measuring right pins at ECU by disconnecting O2-sensor, I was looking to see voltage to drop to 0 but it didnt change. Then I hooked scope clips into sensor black and white pins, beautiful graph but here it makes absolutely no sense: it measured 35V. Reconnected probes and scope, restarted scope program, still 35V, and then measured about 1.6V from AA-battery. This must be some extraterrestrial technology or invention from secret Subaru laboratory. edit: If two white wires are for heating, black is signal wire I should be probing black wire and engine ground, right?
- 10 replies
- sensor
- oscilloscope
(and 1 more)
Tagged with:
Its number 21 in http://opposedforces.com/parts/impreza/en_g10/type_57/exhaust_system/exhaust/illustration_3/ I think its only one there is. Gonna get better pictures.
- 10 replies
- sensor
- oscilloscope
(and 1 more)
Tagged with:
Thank you for good explanation Fairtax! I replaced 2 wire ECT sensor, the 1 wire sensor next to it was for dashboard temp gauge and it works ok. I fiddled with oscilloscope and here are the results: Crankshaft sensor has a crack where its bolted into engine. Is it just cosmetic or cause of ittermittent no start. Crankshaft idle: http://oi57.tinypic.com/9tih5t.jpg Crankshaft 2000rpm http://oi61.tinypic.com/25uhe7q.jpg Camshaft idle http://oi60.tinypic.com/2rpuwb7.jpg Camshaft 2000rpm http://oi59.tinypic.com/23suop2.jpg From the youtube videos where people test O2-sensor, I dont think results should look like these, hopefully i tested right pins. Sensor has 2 white wires and 1 black. o2 idle http://oi58.tinypic.com/2m848yw.jpg o2 idle 2 http://oi59.tinypic.com/osaf44.jpg
- 10 replies
- sensor
- oscilloscope
(and 1 more)
Tagged with:
