Lacyjs9
Everything posted by Lacyjs9
  1. Anybody have one laying around i recently closed my hood without putting it back and now its m.i.a
  2. Its carbed has 3 bolts 2 the same size and 1 different
  3. Need intake manifold bolt part number
  4. It won't let me up load the pic ea82 it's located on the driver side of the manifold
  5. Alright I found em online how many short and long bolts am i gonna need?
  6. Think it be alright to use the same ones?
  7. im talking about the hole where the water reached the base of th carb i have a gasket that has a hole in it for the hitachi but the gasket i used when i mounted didnt
  8. i have the 2701 adapter and i am looking for the base to manifold gasket but cant find the correct one that covers the water port online any suggestions on where to look
  9. 87 subaru station wagon 4 wheel drive http://compare.ebay.com/like/370730046523?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
  10. the car is in great shape 169k it still has original key owners manuals yes the distributor spins freely but has slop in it
  11. the timing belt did break but which broke first or if one could make the other break i dont know . its a 86 sw 2 barrel
  12. yeah it ate the teeath of the gear off the cam i was assuming it knocked the gear of the distributor too but its the gear on the cam pulled the teeth out with a magnet id kinda like to get the whole assembly it seems like it would be easier
  13. ok i have just learned the driver side camshaft has been discontinued.... does anyone have one for sale?
  14. anybody know where I can locate 1 or if I have to by the whole cam shaft. im asking bc I went to buy a wagon today bc the timing belt broke and the guy said he couldn't get the timing right s o I went to check it out come to find out the lil gear that is attached to the cam has stripped any advice?
  15. my passenger side is ran to the air breather so i should "T" it off at the pcv valve and run it into my air breather?
  16. i ran the drivers side crank case hose to the pcv valve
  17. recently done weber swap now i smell burning oil from time to time
  18. yes im sure its not a heat shield
  19. it sounds like something is bouncing around inside it. my concern is if i delete the cat will i loose any power
  20. am i better off removing and replacing it with a straight pipe or just replacing the cat
