18
Everything posted by KiwiGL
Clean Brumby, always liked those massive NZ canopies! My late grandparents built a place in Arrowtown in the 70s so I spend most holidays up there, live in Dunedin rest of the time. Beautiful part of the country, always liked Glenorchy too, there's some great fishing around there up the Rees, Dart, Greenstone, Diamond lake/creek etc...
Not to clog up Nico's thread (insanely fast btw) but that's almost identical to mine minus the H-type wheels and red TURBO decal on rear doors! Mine was an N-reg 1987 GTX turbo with the 3-speed auto and switchable 4wd. No centre diff so FWD on tarmac. Torque steer was crazy! The paint on mine was wrecked too, that blue didn't age well and I think it contributed to the terminal firewall rust in mine.
If you're keeping the standard EA82T and wish to run a WRX TMIC, you should try and locate a 'spider' intake manifold off a turbo Vortex/Alcyone/XT coupe. These have the intake pipe on the rear of the manifold like an EJ vs the top like a standard EA82T intake manifold - it would make your life a lot easier! http://www.ausubaru.com/forum/showthread.php?t=13110 I was going to attach a pic but it wouldn't let me. Google 'subaru spider intake ea82' for more.
Especially considering you're in completely the wrong section of the forum considering the title of your thread.
- 11 replies
- black headlights
- headlight upgrade
(and 3 more)
Tagged with:
Project Haiti - Subaru Utility Wagon for Orphanage work
KiwiGL replied to AdventureSubaru's topic in Members Rides
Pity I sold off my wrecked Foz or you'd have been welcome to the raised Kings and brand new rear kyb struts for the cost of shipping. -
It'll be a 6-speed manual, same gearbox as used in the newer Subarus. No DR unfortunately. This Euro-spec model was also sold here, they're nice cars! Very economical compared to the petrol variants, I never understood why Subaru didn't sell the diesels in the US (even if they were manual-only until 2013).
Having been in a GC8 JDM imported WRX, on ultra-low variable-rate Kings springs, I have to say the ride was terrible even with the variable rate King springs... The problem is that when you lower a car by 30-40 mm you lose that much upstroke in the suspension travel, and a Subaru only has around 70 mm to start with. I know my Foz had about that! Does it feel like you're constantly thumping the bump-stops, or if it's just really harsh?
Try rebuilding the original carb, or perhaps a Weber. Then a 2" exhaust and tune for it. That'll net you some more power. EJ swaps apparently aren't that difficult as far as conversions go, but I haven't peronally doen one. Clean car anyway! one more thing, are those alloys 14"? They look like they might be. If they are then 27" BFGs will go right on without needing to hunt new rims!
Love it. Should have come from the factory like that.
Those A pillars don't look too bad. Once you take the windscreen out you'll have a better idea of the scale of the problem though, mine had rusted down behind the spare wheel well and behind the front mudflaps too - the front end wasn't held on very securely. But mine looked worse than that! Difficult situation owning two...
Didn't scare me off. Personally I'd restore it, the EA82T is a solidly performing engine with new HG. I love the look of the JDMs too, having grown up with plenty like that one in NZ. The HGs killed most of them though. I used to have an EA82T with 3AT 4wd NZDM, rusted out a year back though. If the body is solid, I'd redo the HGs, replace all brake pads and fluids and any shot lines, and look for the damaged interior panels and replace those as needed.
Rescued 1979 Subaru Wagon, now i need help..
KiwiGL replied to Subasaurus's topic in Historic Subaru Forum: 50's thru 70's
Great find, hope you can get it restored and on the road as it's in excellent condition apart from the (few) rust patches. -
WCSS 17 pictures post hear
KiwiGL replied to angerthis's topic in Meet n' Greet. Your USMB Welcome Center
That right-hand drive EA81 RX coupe with the rally decals is seriously rare! I wonder if it's still got the factory works EA81S engine with the twin Weber IDF downdraughts? Would have been epic seeing the late Possum Bourne driving this in the 1982 Rally of New Zealand... -
Sweet work, getting closer by the look of it! Would be a waste to give up now. Pity I'm down south, seeing this in the flesh would be sick
RAM Performance (140hp N/A EA81)
KiwiGL replied to BoneCake's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those SUB4 guys in NZ created some DOHC EA82 heads at one point... Crazy good fabrication. It would be interesting to see how much power one could get out of a built EA82T with these heads and a spider manifold... -
Aussie HI/Lo
KiwiGL replied to Mugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Try Japanese auto wrecker sites, all JDM Outbacks and Foresters and some early Imprezas/Legacies had the dual-range in Japan too. Pre-98 models have a 4-bolt bellhousing and some had a cable clutch setup but just leave 4 bolts out and you're fine. Some early 1.8 Imprezas had a 1.59 dual-range ratio with a 3.9 diff ratio. All JDM Foresters will have a 1.447:1 reduction with 4.11 diffs, Outback/Legacy are 1.19:1 reduction with 4.11 diffs. I'd go the Outback box and put a L-series 1.59 in it (some custom work required) or a 1.447 in it (direct swap) as the first and second gears are physically wider on the Outback gearbox (the 1.447 Forester box would probbaly blow 1st or 2nd behind a turbo engine)... If you're importing an Aussie box, the first-gen (SF) 2.0L Foresters had 1.447 and 4.11, the second-gen (SG) 2.5L Foresters had 1.19 and 4.11, and all Outbacks/Legacies had 1.19 & 4.11. I think your Baja would have a 4.44 diff ratio from the factory so either way you'll need to swap that? Or go 4.44 in the front diff too for more low. Hope this helps. -
If it's an SF turbo, it'll almost certainly be JDM.
If it's JDM, the speedo will end at 180kph, NZDM at 220 or 240 kph. Easy way to tell. Also if it's not registered in the year it was made is a clue too.
Ruby Scoo - the whole story! Loads of pics! Australian L series build
KiwiGL replied to el_freddo's topic in Members Rides
I thought the 5th you went for was the highest available? -
That's all fairly straightforward work for a solid body, you won't regret buying this beaut I'm sure! Nice catch.
Adventure Subaru - Lifted 1997 Impreza Outback (Lots of pics)
awesome idea, what are the legalities of driving a hack job on the road in the us? -
Damn, sorry to hear about that! It's always tough when a car you've put your time and effort into gets smashed, I know that feeling all too well... IDK about replacing the pillars and roof on a monocoque though - you might want to look into where the body panels are stiched together and pull the sections apart there rather than cut and shut, just to make it a bit stronger. Seam welding some more the firewall and other pillars would give the passenger compartment more strength too while retaining the front and back end as crumple zones. -
I'd definitely keep the 4x4 bits off your old GL! It won't take long to remove them before you scrap it and you'll probably want it for future cross-country road trips... Fun DIY project anyway. It looks to me like the bootlid has been bent up slightly at the window side? Doesn't look like it closes quite flush with the rear quarter panels especially in the hinge corners... Could be why it's leaking. You'll probably also want to get onto that rust in the rear arches too to prevent a repeat... I know the pain of having your beloved GL rust out, never good.
Well, she's toast, the damage to that rear corner is more severe than it looks and the fuel filler etc is affected and has been pushed back into the taillight. Basically it needs that entire corner cut out and replaced and that's going to cost more than the car is worth as a whole.
