donbarnes
Location
wilminton, nc
Vehicles
1997 Subaru outback
donbarnes's Achievements
Newbie (1/11)
0
I got in a set of the NPR pistons yesterday and they looked good, coated skirts, and the piston rings looked really good. But I had some concerns with them being in a plain yellow box with no brands and no country of origin, so I emailed Mizumo Auto that I got them from. They answer emails immediately, and said they buy palletts at a time directly from NPR, and some of them come in the plain packaging and some with the brand on it, but are the exact same parts. Without me even asking her to do anything the lady said she was Next Day Airing me a set with the brand markings and a return label to send one set back. To me thats some amazing customer service..
All the old posts about this and it's that easy ? I was leary of hooking into that one because I wasnt sure if it would affect the computer any, so I made me a new fitting today.. The steel fitting that the oil sender bolts into uses the same threads as the water temp sender, and has a built in flange around it, so I took one of them and cut the bottom half off, drilled a 5/8 inch hole through one of those big allen-headed drain plugs from the bottom of the block, then welded the two together- after polishing the weld a little bit it looks like a factory piece..
I'm not using that high-tech an app, it's a 97- But it's for a street-legal rail and all the diagnostic/ non-essential wiring has been stripped down to a running ecu harness. I'm looking to do an electrical or mechanical water temp gauge that stands alone from the computer, although the original temp sender is still there and wired, it no longer goes to any of the factory gauges. I could maybe find the signal and try running it to an aftermarket gauge, but would rather just tap into one the blocked ports the engine already has with a new sender...I have a pic saved on my desktop (but can't seem to repost it, my computer seems to be blocking some options) of someone on here with an older Suby and their water temp sender seems to also be using a steel fitting between the block and sender, and it looks identical to the fitting I mentioned on the oil pressure sender- So I plan of taking one of those fittings and trying it in a water port..I just thought with all the plugs these motors seem to have on them maybe someone would have a ready-made piece instead of the radiator hose ones..
Wanting to mount a coolant sensor for a temp gauge on a 2.5 without using a radiator hose or heater hose fitting- bolt directly to the block somewhere in other words.. Some old posts on here talk about T-ing into the original temp sensor but some of the posters talk about that not working very well because of the probes no longer being in the water stream.., As many plugs as there seems to be on this block surely another method is available? Anyone make a piece that replaces one of the big coolant drain plugs (like the oem block heater does)? How about that steel fitting between the oil pressure sensor and the block- Could one of those fittings be re-used to mount a sensor anywhere for coolant? I know this block seems to have a lot of plugs on it, just not sure which ones goes into oil passages, and which into water...
Two of the valves on one cylinder have a slight mark on the piston and the valves where they made contact after the wreck, and when held to the light just right I could see light shining through where they aren't seating correctly, so will have to change those two... I got it all disassembled last night and one of the pistons had just a little bit of scuffing on the side, I wouldn't have thought twice about putting it back in most of the engines I've done, but since these have a rep for piston slap and I don't know what causes that, I went ahead and ordered a new set of NPR pistons and rings- couldn't find any negatives anywhere on them..
I plan to put new ACL bearings in it, haven't decided yet on the rings- I suspect that I would enjoy saving $100 on them right now, but a year down the road I would be wondering whether were they really as good as good as OEM.. I got the right side head off this morning, the one that had the upper pulley broken in a wreck, and everything looks good. No scuffing or marks of any kind to indicate a valve touched a piston on that side, and it already had a 4-layer MLS head gasket on it- so I'm assuming someone has been into it before...it is also very clean on the outside, has a little bit of white powdery corrosion scattered around on the aluminum, but no oil...
I hadnt found any bad reviews on them either, but hadn't found anybody talking about how many miles they got on an engine with them. Nowadays a lot of people seem to think all rings are the same, but years ago a guy I worked for used to buy those old $100 rebuild kits for 350 Chevys and they would be smoking again within a few months, but my stepdad built a motor for him and insisted he get genuine rings from the dealership- And twenty-some years later that old 2-ton truck is still on the road, so I guess I'm a little biased toward OEM rings and leary of something that is way cheaper than OEM...
I joined today just so I could look for old posts of any bad experiences anyone might have had with NPR rings, then learned your search engine has some kind of weird rule against three letter words like "NPR" or "OEM" I have two '97 EJ25 DOHC motors sitting in my garage and a Kennedy Engineering VW adapter kit ordered for my rail buggy. The first motor was a running 200k+ mile 97 Outback that I bought for $300 with brand new tires on it and stripped all the way down to just a running wiring harness and motor- But I think it was leaking some oil and/or coolant onto the top of the block under the intake, probably from a head gasket, The other motor is a pick-n-pull engine, very clean but hit in the front and busted up a little around the pulleys and covers, also has some Northern rusty bolt issues around the timing covers. I'm aware I could run into some bent valve issues on it... I'm trying to do a quality minor overhaul on the p-n-p engine and save the other one for parts, and I ordered a digital Suby Service Manual link on Ebay today. So far I'm looking at ACL bearings and either Fel-Pro or Ishino gaskets. My question is whether I should pay $170 for OEM rings, or approx $45 for the NRP ones? (1/4 the price). Its a stock build that will probably never be stressed since it should have 3 times the power of the old air cooled motor I'm running now. I like to build things right the first time and have it run for years, but am also on a tight budget. Will a set of NPR rings last just as long as the OEM ones, or is it worth the piece of mind of putting the OEM ones in now and not worrying about them again? Has anyone had any experience with a set of NPR rings that wore out/started smoking sooner than they should have? I found multiple posts about this same question on honda-tech.com when Googling it, but for some reason my computer wouldn't actually open any of the discussions...thanks..
