About luko
- Birthday 11/12/1993
Gender
Male
Location
Wayne, NY AKA Upstate NY
Interests
Subarus
Occupation
Poettinger service technician for the north east
Referral
Google
Biography
Proud owner of a Subaru and would not want it any other way...and also a technician as well
Vehicles
98' impreza wagon
luko's Achievements
Advanced Member (3/11)
3
Careful about pulling the ABS fuse though...If you do that or modify the ABS system and you get in an accident it may be considered your fault and your insurance will defiantly not cover anything...... Good tires do help a bit but does not allow you to stop on a dime when the ABS kicks in..... One thing you may try which I have found to be helpful is disengaging the drive line, so if it is standard just push the clutch in or through it in neutral, if it is automatic put it in neutral. The idea behind this is that by doing this it prevents the car from pushing itself while trying to brake
It almost seems like the PCM is fried....but I can't really say if it is without being there...the only reason why I was that is that is because you are getting a good (or so I think) reading to your PCM (because your scan tool is picking it up)... and a good reading to your gauge....put your fans are staying on and you are having other lights come on your dash....If I recall though the gauge should be about half way, and it should run at about 190 degrees or so...One other thing you could check is your electric fan relay to see if is stuck on, then if that fixes the fans go from there about the other issues
Ej16
luko replied to shapay23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
O2 sensor as well...could be giving your PCM false readings...or you could have a dirty MAF -
Has anyone ever seen a harmonic balancer key way wear out before? and for replacement I was thinking about an aftermarket light weight pulley any opinions on that? Figured since it a boxer that there would be no need for a balancer and instead just a pulley... I seen a topic on dirty impreza about using a light weight pulley just was wondering on some more opinions on it
One of my 2001 legacy's had the same problem... I put a new Beck Arnley coil pack on it, along with new Beck Arnley wires and NGK plugs since I was under the hood and it took care of the problem...not saying it's the same with yours but could be...and that timing belt definitely needs to be addressed as soon as possible
