Everything posted by luko
Thanks for the write up about it, tried it though and the locks never cycled...I have to look into it a little bit more and chase some wires to see just where the power is coming from for the alarm system..Any Ideas on where they are usually spliced into at? It is an OEM Subaru key-less entry system probably installed by a dealer, not 100% sure though
Has anyone on hear done any work with the Subaru key less entry systems? I bought a 98' Impreza awhile back and it came with a key fob, but didn't work.. put a new battery in the key fob still nothing, looked under the dash to make sure everything was hooked up, all checked out okay... Never messed around with any of these but would like to get it working again, so if anyone can point me in the right direction I would appreciate it!....another thing my 01 legacy had the same thing and when I locked the doors manually and shut it it would do the "beep" sound, My Impreza does not though...Don't know if that helps any....and It is a Subaru OEM dealer installed key less entry system
check your radiator cap? is your coolant overflow jug filling up? if so your cooling system is not building pressure...for every 1 PSI your system has that lowers the boiling point by 3 degrees F. so a 14 PSI cap opening at 3 PSI is only lowering the boiling point by 9 degrees F instead of 42 degrees F
