redXTwedgie
Gender
Male
Location
portland or
Referral
everyone knows about USMB
Biography
More Subarus owned than candles on the cake.
Vehicles
1989 XT/1992 SVX/1993 Legacy
redXTwedgie's Achievements
Advanced Member (3/11)
3
The last three Suby HG repairs I've done were because of bubbling reservoir/disappearing coolant, chocolate milk in the crank case, and thick white smoke out the exhaust. Apparently, they don't all overheat because because of HGs. There are a number of components that can cause it. Like Gary started to list. Like I said, I'm still probably going to change HGs anyway just to make it easier to sell, assuming I sell it.
Actually, I wouldn't call it a perfectly good outback. It has a wasted fender on it, the rear hatch has a big dent, clear coat is peeling all over, and there is at least one rear wheel bearing howling. Interior is so-so. And then there's the hole where the tranny is supposed to be. At least it has low miles. Only 157k.
I put my SVX radiator cap on there and it fit much more snugly. So I ran it for awhile in my driveway and got it up to temp and the sponginess in the bottom radiator hose immediately went away. I revved it up to get the driver side fan to come on and it did. So I bit the bullet and drove it around for about 20 mins and the needle never moved. I've read it many times, but I never thought a radiator cap could make that much difference. WOW! When does ever turn out to be the cheapest thing???
Don't worry, I have an umbrella. This is my sixth SVX and I've done 4.44s before, as have 100 others on subaru-svx.net. We even have a computer guru over there who rewrites the TCU to take different ratios and boost low-rpm line pressure and more. While the 3.90 and 4.11 trannys have not held up well to the EG33, the 4.44s have done just fine. They may not have the extra clutch packs, but the ratio helps keep the tranny "out of its own way". We get a lot of broken front diffs on the stock SVX 3.545 ratio. But my question was about the water pump. Thanks for the reply Gary. I'll check those three lower items tonight before jumping into the head gaskets. I've had many failed Subaru HGs in the past, and each time it was obvious. I'm sure my radiator cap needs replaced. I don't need to push down on it at all to turn it. And I have yet to verify that the fans come on, other than forcing them on with the AC. If I decide to sell the motor, I will probably replace the HGs anyway just 'cause.
I just bought a 97 Outback that overheats so that I could swipe the tranny out of it and put it in my SVX. I would like to fix the overheating and either use or sell the motor though. It overheats after about 10-15 minutes of driving. No signs of head gasket issues. No blockage in the heater core. Pulled the t-stat. Doesn't seem to be losing fluid anywhere. With it running, I notice that the hose between the water pump and bottom of the radiator feels really spongy like there is no pressure in there, again with no stat. It is hot, but spongy. Is that a sign of no water pump flow? Or should I look elsewhere. I haven't got it to overheat or the fans to come on revving it to temp at 2000-2500 rpms. I don't have a trip permit yet, so driving it enough to get it to overheat is not an option yet. Any thoughts about the spongy hose?
4 lug redrill for my loyale
redXTwedgie replied to Derekstanelle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No, that would not be a good way to go. Would have to pro done and would be expensive. Not much available in 4 x 140 as you probably know. Just have to sell them and get some 6 x 140 rims and redrill the hubs or add two holes to the rims. Lots of cheap rims available in 6 x 140 pattern. -
It runs all the time if the battery is connected. Fuse was burned when I got it, so it didn't work thru that circuit. I put a fuse in it and its running continuously. Car had alternator overcharge so I'm thinking it probably melted the bat. and switched power together on one of the relays. Replaced alternator, fusible link, combination switch, and other electrical odds and ends. Had no issues for months until I discovered the fuse. So I'm looking way up under the dash, above the fuse block, for the fan relays??? Or am I on the wrong track?? Thanks.
My EJ frankenmotor into my 89 XT gl SWAP
redXTwedgie replied to redXTwedgie's topic in Subaru Retrofitting
Well, I've racked up over a 1000 miles on the swap and all is well. Unfortunately, I don't have a welder and probably won't finish the exhaust before I sell it. I'll just include all the exhaust components with it. FOR SALE Please PM if interested. I'll post in the for sale column in about a week. Looking for four grand. First dibs to those reading this thread.
