Everything posted by Bantum
If you're after a new seat, can try the BRZ / EA86 seat - They have been successful by all reports for later gen BRATS ... Not sure if they'll fit in earlier model though ... Cheers, Bantum ...
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
Bantum replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I do, but would be best to find someone local ... Have you tried a hacker space ? Cheers, Bantum ... -
There be wiring diagrams floating around somewhere here, on FB & AUSubaru ...
I like the mag wheels you had on earlier, hope you kept them ... :/
Front diff interchangeability: The true answer
Bantum replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did some measuring of my own 5MT & R160 Differentials : https://photos.google.com/share/AF1QipM1E6B40KKf2Z3dGy9xVpPCbtRL4gkblZ2tRd291aSfABwY5PSE54eVv1s7PJ5JeQ?key=QXJNWkhHejk2SFBHNFVxc2JzeHBYZkRQYUtVWGNB Nice to know they are not the same ... Cheers, Bantum ... -
I'm doing some research on the R160 diff project & came a cross this thread, would be be interested to know if a locker could be made to fit both front & rear carriers ... Follow the project here : https://www.facebook.com/R160.Diff.Locker.Project/ Cheers, Bantum ... -
The 'R160 Diff Locker Project' has been started over on FB, you're welcome to check it out & fill in the survey. We'll be looking at making a prototype eventually that can be field tested, then it should be available for production. More info here : https://www.facebook.com/R160.Diff.Locker.Project/ Cheers, Bantum ...
Looking for pictures of the new hub ( not previously posted ) + it would be good to see some install pictures to ... Cheers, Bantum ... -
Thanks for the offer Dean, PM sent. -
Complete GL to BRAT Swap
Bantum replied to Divisible_By_0's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yerp - The 5 speed may not fit in the tunnel, as is a bigger unit than old one + the EA82 is wider & will require rail mods. I'd get both drivelines & lay them out, once you have them side by side & note the differences - you'll see what will / wont work. Yes you could cut the tunnel & rails from a donor - lot of work though. P.S. - You'd want the strut towers as well. Ciao, Bantum ... -
Yer, I'd go with an EA81 for a direct swap, anything later will require modifying ... :/ If you do have your heart set on a later model, go for EJ SOHC gear as it should fit without too much trouble. May also require 'massaging' the tunnel, depending on which transmission you use ... Cheers, Bantum ... -
5 lug, hub redrill pros/cons
Bantum replied to crazyhorse001's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hub redrilling is not ideal in my book, so I'd go with the 5 stud conversion ... Cheers, Bantum ... -
Not sure what your after exactly, as this site is more for car engines ... Link to supplier : http://www.ramengines.com/page6.php Cheers, Bantum ...
Trouble Turning off 1978 Brat Fuel Pump
Bantum replied to 2337BRAT's topic in Historic Subaru Forum: 50's thru 70's
You could just un-plug it ...- 3 replies
- Fuel Filter
- Fuel Pump
(and 1 more)
Tagged with:
Bit of an early Christmas pressie : Not sure what I'm going to do with it at the moment, but do stay tuned ... Ciao, Bantum ...
Go Fund Me : https://www.gofundme.com/subaru-xvute Will give this a go & see what happens ... Ciao, Bantum ...
Yes compression test will tell if rings are good ... Are you sure the smokes coming from inside the exhaust ? As there could be a leak externally dripping onto it ? Cheers, Bantum ...
- 261 replies
- Restoration
- Coupe
- (and 4 more)
Could be just a loose wire, You would need to take the dash apart in order to fix it though. Cheers, Bantum ...
Toyota locking differentials in Subaru BRAT
Bantum replied to Divisible_By_0's topic in Subaru Retrofitting
Yep - Have a read of this : http://www.ultimatesubaru.org/forum/topic/160706-rear-differential-locker/ Cheers, Bantum ... -
Far as I know they are in 'testing' mode, so will most likely be next year sometime before we know any more. P.S. - That's in AU so will be like $600 to $800 US ... Cheers, Bantum ...
Haven't heard of any that will fit, as Subaru splines / diffs, etc. are all different than a Toyota ... So it will need to be a custom job & may not be worth the hassle. Ciao, Bantum ...
