3
Everything posted by ford'ssubaru's
I may be mistaken but what you are thinking is a cat is a crossover chamber. My boys and I ran dual exhaust on both rigs right after the crossover chamber. We purchased individual hi end cat for emissions purposes and placed them right before the cherry bombs on both sides. It does not mess with the back pressure and sounds awesome.......
Where do you find 185/80R13 tires?
ford'ssubaru's replied to silverghost88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Order em from Schwab.... If you must have them......I like the conversion but run Pugs...... -
New Loyale owner in Spokane WA
ford'ssubaru's replied to kbaaum84's topic in Meet n' Greet. Your USMB Welcome Center
Welcome! -
EA82 How do we feel about it?
ford'ssubaru's replied to BestCar/OnlyCar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I like the + EA82 posts.....I believe it was given a bad rap because mechanics did not know how to service and maintain it. Parts are cheap and readily available. Cheers, Eric -
I hate to over simplify your issue but you said when gas is poured into the intake it tries to start. When I was troubleshooting a bad injector the engine would fire right up no question then die quickly when fuel was burnt. You said it tries to start. I might retry this test again and see if it runs or tries to start. The engine should flat run then die.... If this is incorrect thinking I apologize, Eric
Hey thanks all! I learned something. Just to be safe I am going to get new ones! Thanks, Eric
Brat far too gone?
ford'ssubaru's replied to BBerry4430's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very nice Brat The above post is the way to go. Get a fab guy to help you with the frame rails. -
Scary question? There is a cone washer. Flat washer and nut....Where is the dished washer? I am worried I don't have them at all? Thanks, Eric
If you search lift kits in the forum a whole bunch of pictures are posted on the process. Eric
CV DRIVE SHAFT
ford'ssubaru's replied to ford'ssubaru's's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am going to do this tomorrow. Thanks! -
CV DRIVE SHAFT
Got it finally. When I installed the lift I had all the springs compressed but all the lower ball joints were still connected. Yes, it was tough to reassemble without the strut compressors. I kicked the snot out of it an connected the lower control arm first then aligned the horizontal bolt. Thanks again! Eric -
CV DRIVE SHAFT
I will give it a whirl. What does DOJ stand for? Thanks, "Eric -
CV DRIVE SHAFT
Yes, It is on and secured.... Thanks, Eric -
Alternator OK but system not charging
ford'ssubaru's replied to afewsubarus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You have soaked the engine harness. There is a harness plug on drivers' side engine compartment that gets brittle and temperamental. I bet you disconnect your connectors and blow them out with air. Install a little dielectric gease and it will be fine! Eric -
Hello All, It has been awhile. I installed a lift kit that was provided on the other topic. The kit has been cool and works great. I tore a CV boot and removed the axles. I replaced the boot and I can't for the life of me get the strut pulled in far enough to the center to reinstall. What am I missing here? Eric
Stuck distributor and cam Sprocket
ford'ssubaru's replied to N0TKG's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When you remove the cam assy cover the dis will come off with it. It can be done with out removing the motor. Eric -
Admittedly I have NOT had this problem. BUT, I do know that it is NOT an interferance motor. Knowing how it is set up though I would gues that your dist gear jammed because of worn dist. You might as well pull the rocker box or camshaft housing. You will probably have to do this anyhow. Eric -
No worries....Threadsert or Keensert.....There is another highquality sert on this sight and a couple of really good threads (not a pun)...
Saweet! Welcome!
Welcome!
New from eastern Washington
ford'ssubaru's replied to EasternWashington's topic in Meet n' Greet. Your USMB Welcome Center
Welcome from the Reardan side of Spokompton! -
New From Delaware
ford'ssubaru's replied to bccr20's topic in Meet n' Greet. Your USMB Welcome Center
Welcome! -
My wife is a UP'er no wonder your postal....LOL. Welcome....
