urabus retserof
Everything posted by urabus retserof
The 50/50 lock is not available with an AT ( according to the dealer ). I'll have to make some calls to find someone who knows enough about the Subie AWD, before a dealer will take it seriously. You would think, that if there is always pressure on the shaft ( whether it is 30 or 70% ) a clunk wouldn't be heard, because it is already engaged. The dealer also said that the ABS applies braking to a spinning wheel. Wouldn't the wheel stop spinning on its own, when power is removed? What happens if all the wheels are spinning, because you're trying to go up an icy hill?
No, I've got mine wired to fry the little buggers, if they get close. Nothing noticeable in the exhaust gas. As for the engine evap, there would still be a noticeable residue. Two of their mechs looked at it, and 1st found nothing, 2nd says clamp was loose( It was spotless, no it wasn't cleaned up ).
You better read it again. 5 year warranty, it's still covered. They checked it 2 wks ago, found no leak . They check it again, they say they found leak. There is no sign of leak. There has never been any sign of coolant dripping, on the ground, or in the engine area. The clamp that they said was leaking, was spotless. Where did the fluid go? This all happened within a month. Before that, the level was fine.
Well I took the 2000 Forester L back to the dealer, after having it pressure checked 2 weeks ago ( no leak found ), and it was still leaking. Loh and behold, the press. check failed this time and they have found a loose clamp was the culprit. BS There has never been any sign of external leaking since I bought the car. They must think I'm an idiot. You can't drain the overflow tank twice in a month, and not see signs of a leak. I wish those darn plugs weren't in such a crappy spot, so that I could do a visual to check for internal head gasket leak. Any ideas?
As I suspected, they said everything is normal. They put the monitor on the ABS and found no abnormalities. I'll be taking it back, if it does it again next time it snows. As for the clunk, it may be normal, but it sure doesn't seem right. Anytime things clunk that hard in normal use, usually means early replacement.
This procedure is no more dangerous than giving/getting a boost with jumper cables. Most makers recommend you don't do this either, but what would you call a guy that wouldn't help you in your time of need? The output of the alternator is ultimately controlled by the rpm of the engine. That is why there is a high idle device to compensate for high drain items like the AC. The regulator does not control the alternator, but is designed to ensure that the preset voltage, and no more, is fed to the rest of the system. This crazy alternator runaway idea, is just that. I did recommend the use of a meter, but in a pinch, this method does work. 99% of the time when an alt goes, there is no output and the car will stall.
I finally got to drive the 2000 Forester L in the snow. A couple of things happened that I didn't expect. The ABS did a slow grab and release, instead of the rapid pulsing that was expected. There seemed to be about 1 1/2 - 2 inches or so of travel, up and down, in the pedal while this was happening. Is this normal for these cars? When I accelerated, there was a slight pause, and then a clunk in the rearend, like it was only in FWD and the AWD kicked in with some delay and play. Again, is this normal? Besides these quirks, the ride was enjoyable, and the steep, snowy hills were no problem.
If your alt. or battery is bad you will get all sorts of weird stuff going on. If you don't have a meter to check the output, just disconnect the battery with the car running to check it. If it stalls it's the alt.that's bad, if not get the battery tested. It's impossible to troubleshoot without a good charging system.
