Boddi
About Boddi
  • Birthday 09/20/1960
Contact Methods
  • MSN
    beggert@nett.is
  • Website URL
    http://home.photohouse.is/
  • Location
    Neskaupstaður, Iceland
  • Interests
    photographic and Subaru
  • Occupation
    engineer
  • Vehicles
    Legacy 3.0 R
Boddi's Achievements
Advanced Member
Advanced Member (3/11)
10
  1. Hi all, i have Auto dimming mirror and is fit it on 2005 Legacy. But my prob is what wire is what. from the mirror is three wire all are two are black and the one is black with a white strip or how it the pin is no 1 for hot or is it pin 2. Thanks
  2. Hi all, Recently i got spoiler for my legacy, but with wrong color. I go to my local paintshop and ask them to paint it. But when I come back on the time it be ready but something go wrong. As the Deltron Acrylic come on the spoler the old paint did dissolve. The use primer paint and sand it after and on the edge the sanding go through the primer on to the old paint there it dissolve. It was like that the old paint did not hold on..... all advise will be very helpfull. Thanks
  3. Last Friday I put new radiator and that fix my heating prob. When the workshopman open the old radiator we see it was almost all clogged. Now my outback run fine.
  4. Hi all, yep Nipper i have change waterpump and belt tension, but it did not change. Next move is cloged radiator. today i drive about 400 mile and one every hill I have to turn on heating fan put it to max heat and max blow and that work out to keep the engine from overheating. But it was very hot inside the car, I have to open all the window to survive .....
  5. ok, nipper the car was sold to Iceland from USA and all warrenty lost. yes I belive it has some major work before i buy it. Few minuts ago I open the time belt cover and on the back side on time belt did not look good, and when I start the motor a strange noice come from the waterpump, so definitely something is wrong with the waterpump.
  6. the mileage is now 45.000 mile when i got it the mileage was 15.000 mile. Yes it is WAY too early..... but this is my problem today I have read almost all service manual to figure out what is broke or what is not working right.
  7. Nipper, cooling fans is allmost all the time on, it is more like the circulation of the cooling liquid is unsatisfactory, two things, lose traction on belt which drive the waterpump or to hevy to turn the waterpump. Some broken in the water pump..... if the waterpump lose traction on the belt maybe the Autamatic belt tension is broken. How about that Nipper
  8. Hi all, what can went wrong in the waterpump or is it maybe belt tension some is wrong. The upper hose is so hot i Can not hold on in for a few sec but the lower hose on the radiator is not as hot I can hold on it by my hand. If i put heat to full on HVAC SYSTEM and the fan on full temp stop rising.:-\
  9. Yep has change thermostad got OE, how is the best way to get airpocket out of the engine ? this is 2003 Outback. No it has full coolant but maybe some isolate inside. What will best way to flush the cooling system ?
  10. No work on cooling system or the engine for a long time, I just finish change thermostat, everything look ok but when I drive up the hill the temp gauge start rising....
  11. Hi all and thanks for all. Now i have heating problem, in normal driving everything look right but when a drive a long high-pitched hill the temp. gauge start rising, when it came to almost red zone I stop the car and wait for a 10 min then the temp gauge was in normal again. Next time i drive the this hill I put heater system on full blow and the heat control on full heat. this was helping to keep temp. gauge rising. There is are normal liquid level in cooling system, both fan is working. Next I like to do is change the thermostat. the car has been drive round 45 k Thanks
