Everything posted by ragingbull
Ej22 swap, How did you lengthen your drive shaft?
Great ideas gents thanks! Sorry to hear about the wreck numbchux! I was just in an accident last week in my 86 alfa romeo spider.. write off. Not at fault. Sucks!! :/
My drive shaft needs to be lengthened 6". I'v taken it to a few machine shops and no one will touch it saying it will never be straight enough.. Any ideas? This is for a 85 Brat with a 85 GL 5spd dr transmission swap.
Anyone know where I can find a shifter assembly and link age for a 85 gl 5spd dr?
Thanks guys! Looks like the linkages are totally different from the 4 to 5 speed.. IL try to rig something up as I can't even find the shifter for the 5 speed.
In the middle of my swap 86 Brat 4 speed to 5 speed and I can't find it anywhere online. 4wd lever is needed too. All help appreciated!
86 Brat EJ22T swap pics
Hey there, I'v been doing the EJ22T swap in my Brat and with much thanks to you all for the guidance. Here is a gallery of the work in progress! http://imgur.com/gallery/EjDxS/ The EJ22T came from a 93 Legacy Transmission is a DR 5 Speed from a 85 GL Flywheel is a 86 XT
What does this piece do under the break cylinder? 86 Brat..
Ok great thanks!
Wondering what this piece actually does? In the middle of a engine swap and wondering if I can relocate it or remove. Probably not remove but I'd like to know what it does exactly first...
Anyone know the part name of this 86 brat Steering shaft rubber bushing?
LOL yah it's a thingy to me too! Anyone think this will work? http://vwparts.aircooled.net/Steering-Coupler-Rubber-1949-79-Type-1-111-415-p/111-415-417.htm
The 31000 disc was a bit too big. Could not modify it either.. I'll try the 31002.
Will a 90's clutch fork work with a 85 transmission?
I think Im looking for part # 30531AA031 But can't find anyone shipping to Canada! Does anyone have this part?
I'm in the middle of a EJ22T swap into my 86 Brat. I have a 85 GL 5spd DR transmission that did not come with a fork. I'm having a hard time tracking down said fork. I'm also using a flywheel and clutch from a 86 XT if that matters. Will a 90's clutch fork work with a 85 transmission? Or know where I can find the proper fork? Here's the 90's fork I can find. It looks very similar. http://www.ebay.com/itm/Genuine-OEM-Subaru-Clutch-Release-Fork-1990-1998-Impreza-Legacy-30531AA111-NEW-/141807059147?fits=Make%3ASubaru&hash=item21045c00cb:g:7hEAAOSwAYtWJqfU&vxp=mtr
EJ22 Swap to GL trannmisson question.
Ah figured out you can't the EJ Flywheel is way to big for the EA transmission.
Doing the swap now. Does anyone know why I can't use a ej22 flywheel and ej22 clutch on a EA transission?
Much appreciated!! Thank you.
Looks like I should get a new one while i have the engine out.. can't figure out the name of it to order. http://i.imgur.com/URXZMWDh.jpg
What radiator for a ej22t Brat?
Looks great thanks! !
Swapping in a ej22t into my 86 Brat. The engine did not come with a radiator. Can anyone recommend one? Preferably aluminum?
Best donor car for EJ22 swap?
Great answer matt, thanks!!
I'm looking for a donor car for my Brat Ej22 swap. I read that the 99-01 version of the EJ22 has a bit more hp? Can anyone recommend what to look for?
EJ22 swap transmission question..
Sounds good guys thanks! I'll have to try and track down the extra parts..
Having a hard time finding the transmission to go into my 86 Brat with a EJ22 swap. I found a 5spd dual range manual from a 88 GL. Will this work? Unfortunately no shift linkage or cross member with it but I'm getting desperate as I'd like to finish this project before it starts snowing!
Can you buy new Brat rockers online?
Sounds good! Would this be them? https://www.millsupply.com/subaru-sedan-wagon-80-rocker-3628542l.php?p=39637 Better than rebuilding from scratch right?
I should be fixing my rocker panels.. Does anyone know a good website to buy them?
86 Brat 4x4 shifter won't fit after 4" lift
The 4x4 shifter is in the proper position. The gear shifter is in neutral in the pic. When you try to shift to reverse the 4x4 shifter is blocking the gear shifter.
Any ideas anyone?
