Everything posted by ragingbull
Hey there, I'v been doing the EJ22T swap in my Brat and with much thanks to you all for the guidance. Here is a gallery of the work in progress! http://imgur.com/gallery/EjDxS/ The EJ22T came from a 93 Legacy Transmission is a DR 5 Speed from a 85 GL Flywheel is a 86 XT
I'm in the middle of a EJ22T swap into my 86 Brat. I have a 85 GL 5spd DR transmission that did not come with a fork. I'm having a hard time tracking down said fork. I'm also using a flywheel and clutch from a 86 XT if that matters. Will a 90's clutch fork work with a 85 transmission? Or know where I can find the proper fork? Here's the 90's fork I can find. It looks very similar. http://www.ebay.com/itm/Genuine-OEM-Subaru-Clutch-Release-Fork-1990-1998-Impreza-Legacy-30531AA111-NEW-/141807059147?fits=Make%3ASubaru&hash=item21045c00cb:g:7hEAAOSwAYtWJqfU&vxp=mtr
EJ22 Swap to GL trannmisson question.
ragingbull replied to Suba_GL_87's topic in Subaru Retrofitting
Ah figured out you can't the EJ Flywheel is way to big for the EA transmission. -
Doing the swap now. Does anyone know why I can't use a ej22 flywheel and ej22 clutch on a EA transission? -
What radiator for a ej22t Brat?
ragingbull replied to ragingbull's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks great thanks! ! -
Swapping in a ej22t into my 86 Brat. The engine did not come with a radiator. Can anyone recommend one? Preferably aluminum?
Best donor car for EJ22 swap?
Great answer matt, thanks!! -
I'm looking for a donor car for my Brat Ej22 swap. I read that the 99-01 version of the EJ22 has a bit more hp? Can anyone recommend what to look for?
EJ22 swap transmission question..
Sounds good guys thanks! I'll have to try and track down the extra parts.. -
Having a hard time finding the transmission to go into my 86 Brat with a EJ22 swap. I found a 5spd dual range manual from a 88 GL. Will this work? Unfortunately no shift linkage or cross member with it but I'm getting desperate as I'd like to finish this project before it starts snowing!
Can you buy new Brat rockers online?
Sounds good! Would this be them? https://www.millsupply.com/subaru-sedan-wagon-80-rocker-3628542l.php?p=39637 Better than rebuilding from scratch right? -
ragingbull posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I should be fixing my rocker panels.. Does anyone know a good website to buy them? -
86 Brat 4x4 shifter won't fit after 4" lift
The 4x4 shifter is in the proper position. The gear shifter is in neutral in the pic. When you try to shift to reverse the 4x4 shifter is blocking the gear shifter. -
Any ideas anyone?
