ragingbull
Everything posted by ragingbull
  1. I did the lift months ago and still can't figure out the best way to fix my 4x4 shifter. I heard bending the clutch shifter isn't the best thing to do.. The reason why it's disconnected is that after I did the lift the 4x4 shifter was in the way of the clutch shifter when I tried to reverse. Your advice and expertise is always appreciated! Here's a pic!
  2. I had the same problem. Ended up being my distributor. .
  3. Sounds good! I'll start researching ea82 swap and rotor swap and see what happens!
  4. I did the 6 lug conversations on my 86 Brat and noticed it's a bit harder to break. Swapping in a ej22 may be asking for trouble without better breaks. What did you guys do to get better breaks?
  5. Thanks for the info gents! Got them in yesterday! Just need to figure out how to install the head rests as there aren't any holes above or below the back Window. . http://i.imgur.com/38mXlYw.jpg
  6. The stock rear seats I have need a mounting bracket. Has anyone here fabricated them before? Are there any design plans floating around or any advice on how to make them?
  7. It broke at the weld on normal driving. I can re weld or does anyone recommend anything else?
  8. Sounds good! Ill dump the Seafoam 1/3 in the gas tank, 1/3 in oil and 1/3 down the carb.. Thanks gents!
  9. Idles at 1000 I'v got a Weber carb. Where would be the best intake/vacuum valve to get the seafoam into the crank shaft? I put better gas in her today but I'v been meaning to do a seafoam anyways..
  10. Usually just for a few seconds after I shut it off it likes to sputter a bit. . Any ideas why or how to fix?
  11. My 86 Brat don't like to start in this cold weather! -10 C she will eventually but if she's sitting in any colder weather than that she wont start. I don't have a block heater and can't really do one as I park on the street downtown. The plugs and wires are newer (6 months), 10w30 oil. The battery could be a few years old but I'm getting good 12 volts on it. I did shoot some quick start in the carb and that didn't help, neither when I tried boosting it.. Any thoughts gents?
  12. Hey there, so the new distributor I got (A1 Cardone) won't go in all the way. It sticks up about half an inch from the engine block where you screw it down. I can feel it slide into the teeth at the bottom of the shaft but it stops there. I wiggled it around a bit being careful not to turn any gears but no dice... The old distributor goes back in no problem. I compared the two and they look identical. All markings used to guide were bang on. I think some more play with the gears may be needed but I'm not sure how much I can do that without throwing the timing off.. Or there's something wrong with the part? Any thoughts gents?
  13. My 86 Brat! I didn't want to post pics until I have the seats in but the guys at my work made this today.. I love it!!!
  14. Finally got her fixed! Turns out it was the ignition module in the disty. . I replaced the whole disty with a brand new one back in August, A1Cardone!! Thankfully it's still under warranty..
  15. Hey can I just run a wire straight from my battery to the ignition coil??
  16. Gloyale, you're so right! It's not the coil, I installed a new one, nothing... I checked the wires and they look ok? I put a voltmeter to the first harness/block. It has two red wires and one green one. Im getting power to them. After that it turns into the wiring harness and I have no idea what to do with that.. Where should I start?
  17. Ill check the wire for sure.. If it's the coil, I see a Hitachi and Nippondenso options for coils.. Do they both work?
  18. Im thiinking ignition coil... I used a volt meter on the + and - on it and I got nothing with the car turned on... Is this ignition coil specific to the brat or can I get a universal one?
  19. OK Ill give it a shot tomorrow.. I tried holding the choke open, no dice...
  20. That's why I can't find it! Lol... Okay so I've tried everything tried boosting, tried popping the clutch, tried dumping fuel in the carb, banged in the ignition coil with a hammer, not too hard, checked fuses.. no go.. it's turning over but no ignition much like the video i made but not starting. .... any thoughts guys?
  21. I'm wondering if it's my ballast resistor.. Does anyone know where it's located on a 86 brat?
  22. I was thinking about getting this one? http://www.accessoriesonline.com.au/shop/product.php?productid=16661
  23. Fuel filter is new, air filter is clean. Iv been told the fuel pump either works or it doesn't. Is the that tapping noise the fuel pump? How do I fix that noise? I have a weber carb installed if that helps the diagnosis. I'm away for the weekend but I can take pics of the coil wiring when I get back Monday! I really appreciate the intelligence on this thread gents. Thank you.
