92loyale59
Everything posted by 92loyale59
yes king springs for the win. i love my king springs
oh i was thinking thats the only other person it could be . im the guy with the lifted loyale that you have a picture of at ski bowl . cars looking sweet man cant wait till you can hit the trails with it .
yes that makes sense
it s . sounds like you want his blueprints so you can make it your self . these kits are way over kill on thickness dont think there should be any concerns
I would say iys timing for sure. I had this happen once . One of the cams probably moved when installing the belt . After you put both belts on make sure the cams are 180 degrees oposite
http://www.ultimatesubaru.org/forum/topic/140101-my-92-loyale-build/?hl=%2Bloyale+%2Bbuild. I havr basically the same lift . 2 inch with sub frame drop
Hey do you think you could post a picture of how you got your snorkel to hook up to your intake manifold. Are you using a stock air box?. I just got my snorkel today and trying to think of how I should connect it from this fender to the manifold. Thanks a lot
. Could i use those 4 runner shocks on the rear of my loyale with stock height king springs that im all ready running? If so whats the down side to using them
We took the hatch out a few months ago up to silver fox to wheel it . Got pulled over on the way up for bad tags but still made it to the mountains
Looks sick with basket man
so i blew upp another front diff in the tranny . this time i could limp it home but when i drained the fluid teeth from the ring gear fell out . does this happen to anyone else? could it be happening because the flywheel is not the step? any info would be appreciated. heading to pick n pull hope i have some luck finding and removing another one.
uneven tire wear on a lifted rig?
92loyale59 replied to nick1208's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mine are cut to 17.5 degrees -
King springs helped because they were a stiffer spring but mine still lifts up a enough to wear the outside a bit . what is the degrees of the cut for your front strut lift blocks? -
can i get a adress so i can get them sent please
a few sjr ea lift blocks bent on me for a 4 inch lift and when itried to comunicate with sjri got one reply then non . wasnt satisfied with the servixe whatsoever.......just my .02
where did you get that snorkel !!?? i have been looking for one that matches the angle of the hood and windsheild
blew up the front diff in the tranny friday morning on my way to work..... will post pictures when i take it apart . looked in the drain bolt hole and saw the ring gear with barley any teeth left on it . chunks of metal were on the drain bolt. also managed to break the cluth fork on the pivot point also so i used the one off my single range tranny . installed a new one on saturday at ssi and my buddy patrick helped and that made it not take long at all
Nice. Yeah there was no other cars in the parking lot there was an Evo but it slide into the snow wall. Couldn't get much more videos of me that night though cause with wind chill it was negative 15 degrees
