92loyale59
Everything posted by 92loyale59
  1. i was wondering if felpro head gaskets are a good gasket for this engine and also if i can reuse headblots. i have heard lots of different things about both those so i figure i should ask here. thanks
  2. alright well for the sake of getting this ready before timberline opens i will probably clean it up to the very best i can and just throw it together . then on the side i will probably start building a fraken engine. thanks a lot of the help every one. if i find some where that will do it pretty cheap then i will replace the rings
  3. sweet thanks a lot. i will probably go that route then. do i need to hone the cylinder out at all ?
  4. so if i replace the rings would i also need to replace oil control rings or are those the same things . thanks
  5. oh well thats a good thing to hear . i will just continue to clean the short block and the heads up and i guess just re seal it with new timing parts and ect. thanks for the help milesfox and crazyeights
  6. alright thanks a lot i will give that a shot. i actually just disassembled that engine yesterday though and it had been running good apparently before that. i just bought it used. but there is already a large amount of scuffs on the cylinder walls . does that mean it needs to be honed or will it run fine if just cleaned and re sealed
  7. so today i removed the heads off my ej 2.2 that i am swapping into my loyale. when i removed the heads i saw lots of grime sitting on the inside of the cylinder walls and around and on the piston. also the cylinder walls are terrible scratched i would say. im not sure what my options are for fixing it or if i just need to replace it or what? . any help would be really appreciated, thanks
  8. Here are some photos of my car with the D/R tranny installed I began to disassemble my engine today . when i got the intake manifold off i noticed a lot of what looks like oil that leaked into the intake ports and on to the valves on all four intake ports. Does anybody know if that will cause a problem ? was it just bad intake manifold gaskets? do i just need to clean it up or can that cause a problem ? here are some pictures of the engine also i was wondering if this looks like it has a blown head gasket . my guess is yes is this a problem or just needs to be re sealed? Thanks a lot in advance for any help i am not to familiar with ej series engines .
  9. so today ended up being nicer than i thought it would be so i had a friend come over and help me install the tranny. I also hooked up the linkage and the driveline. Im pretty excited to find out how the D/R tranny will drive compared to the S/R
  10. so i have been busy working and the time off i get its raining so not much has got done . today i replaced the steering rack and got the tranny under the car and ready to be installed .i got the steering rack from discount imports and it is re manufactured . it says koyo on it and so did the stock one .
  11. took my wiring harness into SSI today so it can be trimmed down. i also picked up an EJ adapter plate and brought my flywheel in to get drilled out. tomorrow i plan on clearing out my work space and start tearing down the EJ so i can reseal it.
  12. got my EJ 2.2 engine yesterday.it is out of a 93 legacy auto. its a bit leaky looking so i think im going to reseal it before i install it . heading to u pull it to see if i can get a ECU and wiring harness along with some sensors from a 95 or 96 legecy manual
  13. search for it you will find lots of info . they do come in most turbo models and yes you will need to mod it to make it work in your rig probably
  14. so i brought my D/R tranny into GD's shop last week to get resealed . i figured it couldnt be to hard to do my self but i just dont have time with work and i would rather someone who knows what he is doing to mess with the tranny.cant wait to get this all back together
  15. where did you get you exhaust. im about to swap ,my loyale and i want the same set up basically . thanks
  16. i sadly do not i took it off and put it on my old loyale befor i sold it because that one had a bad bent bumper
  17. summer wheels and tires and this is my winter tire and wheel set up i also have a extra general grabber with about 70% tread for a matching spare
  18. so i am hoping some one will be able to help me out here. i bought a full set of white powder coated peugoet 14 inch rims and one of them were a bit bent on the out side edge . i have these pictures but im not sure how easily it can be seen . im basically wondering if i am able to bend the edge back flat some how . or how much it will even affect the tire holding air?. thanks for the input i already tired hammering it back with a block of wood and it didnt do much but mess up the paint
  19. i just ment that small elbowed coolent hose . if you need a picture i can get one up here just let me know
  20. There might just be a very small hole in one or the hoses for either the heater core or maybe the hose from below the thermostat to the intake. i have gad it happen to mine before and i couldnt tell where it was dripping from untill it was being revved up and already warm ?
  21. i almost picked that gl up for my self a few weeks ago. glad somebody on the forum did though. when i get my subi back together we should go wheeling at some point.Also i have a good friend with 16 acers who wants to have a subaru rally in his fields
