JuhaKankkunen
    2
Everything posted by JuhaKankkunen
  1. Check valves. Did you check if you have motor oil level descend?
  2. it doesn´t seems to be a crack for me. Its only a defect on the aluminium.
  3. My engine starts #557 but is a JDM. It is 1980.
  4. Did you also change inside cv joint, I meant the ones that's go nearby the gearbox? As someone says, the noise could be the brake calipers too.
  5. Hi! you have some many details to know. Fisrt of all you need an specific tool to adjust number 1 and 9 bolts. The sequence of torque you can see it on google images searching EA81 Head Torque, you will find the sequence there. The torque you must apply is 22 ft-lb then 43ft-lb and finally 47 ft-lb, don´t need to use any sealant and you do not need to remove the cam towers because thats bolts (#4 and 5) also adjust the head. Finally 6 mm bolts need 8 ft-lb torque, and you hae to torque thats bolts after all the head torque Drive the car for at least 1000 km and then, with the engine cold, retorque to 47ft-lb-
  6. I´ve only seen one mounted on an 99 Outback in CT, it´s works perfect but never in and old Subby!
  7. Ok, mine it's not a brat but it's a wagon with the ea81 stock engine with manual 4 speed. I use it daily for almost 50 km and it runs really nice and smooth. 10 liters per 100 km . Stock hitachi carb!
  8. Hy, i have been some time off line with some password problems to loggin. I´m here again and want to share with you my last muddy day!
  9. Hi, just want to know what is the best CV Axle Shaft do you think for buying on Ebay. It is for an EA81 4WD, thanks!
  10. Thanks, but it was almost impossible to found the OEM Subaru 8 spokes in Argentina....... Jackmans, for sure, are impossible to find in my country!
  11. Another pic today working!!! Sorry....but what jackmans means??
  12. Just bought a wheelset of five 8spokes OEM. I must take of all the old paint with sand work. And do a new painting job. \
  13. Nice!!!! It's the same color that my 1981 Wagon! The front suspension adjuster nuts turns hard because there is a lot of dust there and maybe nobody turns them since long time ago.....just ad some WD40 and ready to go again. Use a 21 mm wrench for that work. I have never any trouble using rear suspension rised up. Please post some interior pics! Martin
  14. 227300Km 1981 4WD sedan EA81 198500 Km 1981 4WD Wagon EA81 236000 KM 2001 Outback
