TallonX
Everything posted by TallonX
  1. All I've seen on this transmission states 4 gear ratios this 2000 Impreza is going through 5 gears, any thoughts?
  2. Sounds pretty close to what a clogged catalytic typically does
  3. With how the grade is on some of them roads... Might as well call it a mountain XD
  4. Power to the switch should be killed when you press off on the heater control panel
  5. The fuel additive I swear by... B12 Chemtool. Pour a bottle of that in next fill up (if available where your at of course) followed up by a quart of Marvel's in the fill up after that
  6. Damn guys... And I thought what I did in mine was pushing the envelope... Some rigs will surprise ya tho, bout the worst I've done is haul a 78 Chev 3/4 ton with 2 350s and 3 TH trans in it's bed down I5 from just outside Olympia to Rochester (30 mi) in an 88 Samurai... only thing modded about that thing was the exhaust and a rust weight reduction lmao XD
  7. If the throw out bearing is bound up creating pressure against the flex plate it will be acting like your foot is on the clutch peddle
  8. Almost sounds like the throw out bearing is binding somewhere did you get it positioned correctly on the clutch fork?
  9. Wheel bearing? Hell mighta been a double edge sword... Wheel bearing or dragging brakes creates excessive heat which in turn warms the rim increasing temp of the air in the tire over pressuring (10f = 1 psi) breaking a belt in said tire causing a wild ride...
  10. In my case it was a lean run condition, might be yours to
  11. They also love PURE gasoline How to remove ethanol cheaply... Mix a quart of water with 4 gallons of premium shake vigorously then let sit for 24hrs the water will attract the ethanol and sink to the bottom of the can siphon of the good stuff and boda bing
  12. 1. Some cars require a decent temp to allow for fuel atomization 2. Carb'd runs 8 btdc and will run up to 20 btdc 3. Just as long as the resistance values are with spec to stock, hotter coils work just fine but you only need to go hotter under higher compression I've been considering Frankensteining up an intake off an SPFI and running a single barrel holley 190 for shits n giggles never know right?
  13. Had my exhaust blow out in the middle of Olympia en route to fix a rig Valentines day just never got around to posting what it sounded like...
  14. Been reading a bit about this, should I do it? Has anyone else done it?
  15. Mines a 1987 carb'd as well, I think it's likely that something stupid happened coincidentally. Pop the top of the air filter, open the butterfly for the choke dribble a Lil fuel down her gullet n see what happens, not a lot table spoon worth more or less and give her a roll, don't try and force it by hitting the gas just let her roll, if she burps or fires to life, fuel pump is the winner, smack it up a bit see if it frees up
  16. Mines a 1987 carb'd as well, I think it's likely that something stupid happened coincidentally. Pop the top of the air filter, open the butterfly for the choke dribble a Lil fuel down her gullet n see what happens, not a lot table spoon worth more or less and give her a roll, don't try and force it by hitting the gas just let her roll, if she burps or fires to life, fuel pump is the winner, smack it up a bit see if it frees up
  17. I seen the question asked but I didn't see the answer, fuel infected or is the beasty carb'd?
  18. Mine makes the same noise from the starter, cheap, weak battery in my case. Your soundin a bit low on juice as well from that sound clip.
