pghiocel
Everything posted by pghiocel
This weekend, we race again. This time in hot hot Buttonwillow, CA. Temperatures are supposed to be close if not over 100. Here is a preview of the weekends race. http://hooniverse.com/2014/06/18/24-hours-of-lemons-button-terrible-preview/ So here is to hoping that 3rd time will give us the good luck to run all weekend. We are still running the 9:1 compression motor with turbo. Hopefully running race gas and an oil cooler will help keep it from detonating. I also managed to remove the Hill Holder and put in a new Master Cylinder.
Next morning we put the engine in And send one of the other racers out. And we go! 1 lap, 2 laps, 3 laps... the entire rest of the day in fact. We even take the checkered! 80 laps! Better than our first race last year at Sonoma Raceway where we made 64 Laps. I'll take it. Also we were not in last place and in fact could have over taken 2 other cars if we had been a little faster at switching drivers thru out the day. But what this? Will we win an award? We certainly didn't win Class C. A 1973 Porsche 914 won that by 95 Laps over 2nd place in C Class. Not Heroic Fix. That went to a team whose trailer caught on fire, their tow vehicle started having paneling peel away which they had to duct tape. Then when they got to the track and raced, their car lost its transmission. Not Organizers Choice. That went to a 1980 BMW 320 which was done up as an M1 Not I Got Screwed Either. That went to 1980 Rover SD1. A Rare Car no doubt that would have easily won another major award if it wasn't for so many rare cars racing in this series. Each race has a specific award to that track and for MMP, it was "Miracle of the Gulls Memorial Trophy" (in honor of Utah's Mormon Heritage). This went to 1973 Jensen Healey that also blew up its engine, a Lotus Twin-Cam thing FAR FAR MORE RARE than our EA82. Surely there was no replacement even within 1000 miles of Salt Lake City, or there could be one 50 yards away in some rented garage. True Miracle. We weren't going to win Index of Influency as we just didn't do well enough. It went to a 1950 Dodge Truck which ran the whole weekend. It turns out we are awarded Judge's Choice for continuing to bring the RX to LeMons races and our effort to bounce back from an aweful first-turn first-lap in front of everybody engine melt down. In fact, one of the Judges was testing out a 2015 Impreza Sport and wanted to take a photo with the RX for his article.
Well Saturday Morning comes along and we change the oil. We had used Engine Breaking Oil (high in Zinc) and wanted to switch to regular Oil for the actual race. I am the first driver in the car and I usually spend the first few laps (which are under full course Yellow) to shake down suspension, brakes, engine, tires. Brakes seem a little soft but nothing unusual, Water Temp looks fine. Oil Pressure is a little low... hmmm. 2 Laps go by and the Oil Pressure isn't going higher. In fact, it is going lower. First Lap, well over 45, 2nd lap can't get more than 40, 3rd lap 35, 4th lap 30 psi. I radio in that Oil Pressure isn't looking too good. As I come down the straight away, I see the pressure go down to 20 and I think to myself that something is wrong and I need to bring the car in. Problem is that the exit from the East Configuration is right before the last turn of the straight-away, I would have to go one more lap. As I continue down the straight away, I see the Green Flag wave! The Race is on! 68 Cars, 4 Drivers per Car, all watching the start of the race weekend. Our RX putting down the straight. I try to get on the gas for the first turn. BOOM. A poof of smoke and the engine stalled. I had barely made it around the 1st turn and we were done. Cars it towed back into the pits and we pop the hood. We all focus on a cap. A radiator cap that was sitting next to the radiator. OMG we just blew up our newly built engine because of user error. It turns out we had boiled all the water, Water Temp never go water so it never read hot. A Water Pressure Idiot Light or maybe double checking our radiator cap might have saved us such an embarrising mistake. After we cooled the car and put water back in, our worst fears were confirmed: bad knock meaning probably broken/melted rings and bearings. So what can we do? Well there are two Subarus near Salt Lake City, a 92 Loyale and an 87 GL. Lets go look if we can fish a new short block! So at 10:30 in the morning, we are off to the junkyard. The first is a 92 Loyale and it looks absolutely perfect on the outside. I say "uh oh this car looks too perfect". See Cars only make it to a junk yard for 2 reasons: Broken Internals or a Smashed Body. I was hoping for the later. After opening the hood, we see an oily mess of an MPFI EA82. Oil and Dirt just everywhere out of every hole. It had 300k miles on it. Time to go look at the 87 GL! We get to it and it has a crashed front quarter panel. We open it up, SPFI Carbeurated EA82. A bit dusty, broken timing belt, but no oil leaks. 140k miles. Lets pull us an engine! We get the engine out and pull off the heads. A bit of an issue because one of the bolts that holds the cams to the heads on each side was rusted. Had to hammer an 11mm on. But after they come off, it looks great in there. No head gasket issue, cylinder walls look great. Engine turns over. We also took a bunch of bolts with us. We make it back to the pits while other cars are turning laps. A Masserati Bi-Turbo turned 3 laps and then died, everybody said "Well at least you did more than the Subaru". We were determined to prove otherwise. While I and another of my race car drivers pulled the engine out of the RX, the other two drivers went to work cleaning the short block we got from the junkyard. Having gotten the engine out, we moved onto dismantling and building the new engine. My engine building station And we are done! Ready to put the new hybrid engine back in and see if it runs! We are all pretty tired and so I make the decision to wait until the next morning to put the engine in. Having missed all of Saturday, we aren't winning any race and certainly don't want to make another "radiator cap" mistake.
Miller Motorsports Park Race Report So earlier this month, we took the RX to race at Miller Motorsports Park. This was the 2nd race for the RX and the first with a newly built motor. Most California Races usually have over 150 cars, so this race having a relatively "low" number of cars at 68 meant we were going to have little competition in Class C. We added a new started switch (the key would wiggle in the ignition and turn off the car) Cool suit cooler for comfort and extinguisher for safety We spent Friday breaking in the engine. I kept it under 4k RPMs and genetly went up and down the revs. With the new engine, we started finding a water leak of sorts. In between test sessions on Friday, we kept checking and verifying that the water lines to the Turbo were no leaking. The engine bay One of my teammates showcasing our new shirt while my other teammate helps me look for the water leak Close up of the shirt Of course, we were also double checking that the radiator was filled. Later in the day, we finally manage to track down the leak, it was the top turbo line but at the manifold and NOT at the turbo. We also replaced the rear diff fluid. At tech inspection Now all thru testing Friday, Oil Pressure and Water Temp looked great. I still have not had time to add the usual engine telemetry (Oil Temp, Water Pressure, etc) so we were just going by what the RX was telling us. I was paying alot of attention to Oil Pressure. It was at about 45PSI around 3k RPM and seemed to be doing the 10 PSI per 1k RPM rule. Water Temp was solid.
Some Gen 3 Heads to clean Meanwhile we took the old engine out of the car. Short Block ready for heads More Head Cleaning Done (note the marks from some previous carnage, maybe piston rings) Where the cleaning happens The valves ready to go in. Longblock Kind-of-Assembled Ops. Need to fix this....
So we are planning to attend the LeMons race at the end of the month at Miller Motorsports Park in Utah. If you are in the area and want to watch crappy cars with rediculous themes zoom around or rust in the paddock, feel free to stop on by. http://www.24hoursoflemons.com/events-results/article/127-return-of-the-lemonites I am making a tshirt for our team. Initial Version Here are some pictures of us updating the roll cage and building a new engine. Album: http://imgur.com/a/89V9O Installing Radio Updating Rollcage for 2014 Rules We aren't going to retheme the car for this race. We will be adding some new decals and touching up the paint next weekend. I was able to get a 2nd set of Peugeot 15" rims New Lugs thanks to @4x4brat Oily mess from broken CV boot from last race The Broken CV Boot New CV Boot & Axle
Those look like some nice rims. Wish I could grab a wider set of 15" or 16" for our race car.
EA82 turbo heads for sale
pghiocel replied to philoftheblanks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmm, you may have posted to the wrong forum section. Here is a picture to explain the head generations. If you are still willing to entertain the idea of shipping, I would be interested. -
I am not too sure about Autobahn. LeMons is there July 26 & 27 and rumor is that it will be a full 24 hours day & night race (Despite the name, most LeMons races are really just during the day Saturday and Sunday). So I'd really like to make the trek out there for the 24 hour race but I am only going to make one long distance trip and we were thinking about going to The Ridge Motorsports Park in Washington the week before. I guess I will see how I do with funds next year. And of course I need to get the car smog legal so I can drive it (I don't own my own truck & trailer). It is really a shame that the previous owners swapped out the EA82T as it originally came from California. Oh well
So we ended up getting 3 gasket sets: - Subaru OEM Gasket Set (for alot of odd and rare gasket pieces) See: http://www.ultimatesubaru.org/forum/topic/42383-ea82t-gasket-set-contents/ http://www.ultimatesubaru.org/forum/topic/142272-looking-for-piston-pin-circlip-part/ And then off of Ebay,we bought two kits (I think both with Timing Belt kits) - Eristic - Evergreen The Eristic seems great and very similar in quality to the Subaru OEM gasket set. We were pretty happy with it. We will probably not get the Evergreen one. What headgaskets are you using? Good luck with your build!
The Organizers and Judges really liked the car so much that they made mention of it in their Post-Race Wrap Up Video!!! Go to about 45 seconds in to see our 15 seconds of glory!
Right now it is an entirely stock EA8T. But we plan to slowly upgrade the car as budget permits (after every race, you tell the judges/organizers how well you did and what if anything broke and they usually give you some sort of budget (under $500) to fix and prepare the car for the next race. Our plan is to eventually use an Intercooler and TD04 with the 2 EA82 engines that we have. Once we have had some success (or failures) with those 2 blocks, we will probably have enough of a budget to switch to an EJ22T or EJ25 which will give us a far better hp-to-weight ratio. The suspension is also very soft on the car right now so we will have to also work new shocks and perhaps a little lowering or stiffer springs. The painting was actually done by us using Rustoleum Paint (after a few restoration welds around the window and a couple of panels) and alot of Painter's Tape. Use Frog Tape for very detailed sections where typical Painter's Tape might leak on the edge. I'll get you the paints we used. We based it off the Safari Rally Kenya pictures we saw on the internet and a book that I bought on Subaru Rally. I can post pictures and links if you don't see them on our facebook page. I also plan to learn how to develop some decals (Marlboro, Kenwood, etc). I'd also like to get some reproduction RX decals. I found Retroroo's website but he hasn't responded to me yet (I assume he is busy).
That is a good question. Our next race will probably be in May at Miller Motorsports Park in Utah, so I have quite a few months to further work on the car before that race. So my initial plans it to investigate the oil leak we had (I believe it is part from the engine and part from the power steering pump) and get the car legal. Once I do that, I might get it aligned and I'll find out how much it weighs. ~Patrick
We are a LeMons Race team and have started campaigning a '87 RX. Originally, we raced an '84 300zx for 6 races in the past couple years but we are all Subaru Owners ('05 STi, '00 RS, '06 STi, '12 BRZ) and because Subaru Cars/Motors are not very common in LeMons, we wanted to try and raise it to contention. We also wanted something that had not been raced yet in LeMons and both the XT/XT6 and RX have not. So earlier this year, we picked up an RX. It was the RX in Bend, OR. (You can see my '05 STi there too). You might remember that it had an MPFI NA motor swapped in. And was generally an Oily Mess With some rust spots too Well, we ended up picking up a 2nd motor (Turbo from a 90 Loyale Wagon) but it too had some issues: Well, we put together various parts to put it back into its Turbo form and we managed to make if to the 2nd day of the last race of the season at Sonoma Raceway this past weekend and went from Start to Finish!!!! Here is list of picture albums of our build of the engine/car/roll cage. While it was our 7th Race, it was our first time putting any engine together and our first time building a roll cage. Theme Material https://www.facebook.com/media/set/?set=a.642585902448645.1073741834.392335147473723&type=1&l=560f3bf560 Documentation https://www.facebook.com/media/set/?set=a.642179492489286.1073741833.392335147473723&type=1&l=a2c723e688 First Work Weekend https://www.facebook.com/media/set/?set=a.631860233521212.1073741828.392335147473723&type=1&l=e69603ab82 Taking Apart Turbo Engine https://www.facebook.com/media/set/?set=a.634061279967774.1073741829.392335147473723&type=1&l=733934dba1 Pulling the NA Engine from Car https://www.facebook.com/media/set/?set=a.634065436634025.1073741830.392335147473723&type=1&l=db6580406a Pulling Interior https://www.facebook.com/media/set/?set=a.634461339927768.1073741831.392335147473723&type=1&l=6d632330de Further Engine Work https://www.facebook.com/media/set/?set=a.638521222855113.1073741832.392335147473723&type=1&l=783f8fc493 Engine Rebuild https://www.facebook.com/media/set/?set=a.643829988990903.1073741835.392335147473723&type=1&l=d6eb7577ad Cleaning Up Sound Deadening Material https://www.facebook.com/media/set/?set=a.645801382127097.1073741836.392335147473723&type=1&l=06cde21dde Seat, Steering Column https://www.facebook.com/media/set/?set=a.650288691678366.1073741837.392335147473723&type=1&l=96c4cd5b27 Roll Cage: Part 1 https://www.facebook.com/media/set/?set=a.659849440722291.1073741838.392335147473723&type=1&l=7b24cef617 Thanksgiving Week Work https://www.facebook.com/media/set/?set=a.665887506785151.1073741839.392335147473723&type=1&l=4238ee63d0 Engine Building and Final Prep https://www.facebook.com/media/set/?set=a.671735896200312.1073741841.392335147473723&type=1&l=1801b7292e Pictures From The Race https://www.facebook.com/media/set/?set=a.671402002900368.1073741840.392335147473723&type=1&l=58f671f333 Pictures Of Other Cars From The Race (The Orange/White Beetle has an EJ22 in it and there is a Subaru Legacy Wagon). https://www.facebook.com/media/set/?set=a.671749096198992.1073741842.392335147473723&type=1&l=d1954b6bcf Originally I was planning to make posts on everything that we have done but it has been a whirlwind of work for the past month to get the car ready and so this first post will be just a history of what we have done to the car. Hopefully in 2014, I can make more posts as we fix/modify the car. I also have some interior and AC parts that I am hoping to sell. Thanks to a couple members on here who sold me various parts for the car. They worked out great! And thanks to USMB as it has been a great resource. Thanks for looking and have a great new year! ~Patrick
dual range swap into loyale?
pghiocel replied to Tman1058's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't suppose somebody knows the serial codes for these transmissions (I've found the various Subaru Transmissions Serial Tables from 1990s+ but not from the 80s)? I picked up a 2nd transmission for our RX but have been having trouble determining if I would need to do anything else (different axles, etc) in case our original D/R fails us at the track. it is an 1987 RX. The spare transmission claims to be from an 89 GL. I've included a couple photos. Thanks. -
5 MT Full Time versus 5 MT in an '87 RX
pghiocel replied to pghiocel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
We haven't started work on the car yet as I have my wedding to deal with first. We are hoping to get it ready for the December race @ Sonoma raceway. I am not sure if I would consider it in mint condition. While the body is in good shape minus a few rust spots, the interior is pretty much ruined and somebody swapped in an MPFI EA82 and it is leaking oil pretty badly from the front (I am guessing the usual oil pump seal as it looks to be coming off the oil filter). I bought an EA82T out of a 1990 Loyale (it fit in the back seat of my STi) that I hope to put in it and get it smog legal. But I understand the sentiment about the the stock parts on it and will definitely post any parts to here that we end up taking off the car. In addition to doing the motor swap, I have a stock WRX intercooler and parts from our oil cooler for the 300zx and I was looking to get a good radiator. I do agree that keeping it cool is our primary concern. -
Thanks for all the advice. I'll definitely detail how our work and races go with the RX. We are all subaru drivers ('05 STi, '06 STi, '00 RS, '12 BRZ) and we have raced 6 times with a 300zx but wanted to switch to a Subaru since they are not represented much in LeMons. The way LeMons works is that after every race, you tell the judges how you did, what broke, etc. They give you a budget to fix whatever you want to fix or replace. So our plan was to campaign with the RX as stock for a while and build up a budget to swap to an EJ Engine and eventually Transmission. Right now we are a bit over budget but considering that there has not been an RX in a race yet and only a couple other Brats/Imprezas in Lemons History, I am sure they will overlook our budget. Plus, the RX suspension is super soft so I am not sure we are contender for much even in Class C. I think they worry more about the E30s and Miatas when it comes to the $500 budget. -
Forgive me for starting a new thread, I've been trying to research this thru the search function but haven't gotten much success on a definitive answer. I plan to campaign an '87 RX in LeMons. It has a working 5-Speed Full Time D/R transmission. Though I can't get the "Center Diff Lock" light to turn on, so I have to investigate that. In my LeMons experience, it is good to have 2 of everything so I am looking for a 2nd transmission as a spare and I found a rather cheap 5MT from a Subaru XT Turbo. From what I understand, it has a slightly different gearing. 5MT: Gear Ratios: 1st 3.545 2nd 1.947 3rd 1.366 4th .972 5th .780, Rev 3.416 Low Range 1.595MT Full Time Gear Ratios: 1st 3.545 2nd 2.111 3rd 1.448 4th 1.088 5th .871, Rev 3.416 Low Range 1.196 Is that the only difference? Is it a straight swap? Given the application (road "racing" hehe), any recommendations on using any other Subaru transmission? Should I run a Transmission Cooler? The eventual plan is to use the EA82T for a while but eventually swap in an EJ motor. Thanks in advance for any advice!
RIP 3door, I'll miss you...
pghiocel replied to Ibreakstuff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya, SF can be rough. Sorry to see your crash. GL with the new RX. -
I was the "other people" looking at that RX. We also don't have a tow vehicle so I told the owner if you "bailed again" as he put it (sorry) that I would arrange to pick it up with a friend. Most of my drivers are Subaru Drivers (05 STi, 01 RS, 06 STi, '12 BRZ) so we've been looking for something nice and unique and subaru for LeMons. I am not sure that LeMons is anymore wear-and-tear than rallycross! Good luck with the build!
