matt167
    5
Everything posted by matt167
  1. It's more common than you might think.. Find an old work van and set up shop in the back.
  2. Decent hydraulic compressors cost about $130. If your going to do 4 struts, a shop will probably charge $20 per strut to take the time and do it and many shops will look at it as at least 1hr of labor.. So that's gonna be $80-100 plus the gas to get to a shop.. If your planning on 4 struts, just buy a $130 compressor. http://www.ebay.com/itm/New-Coil-Spring-Compressor-6600-LBS-Auto-Strut-Hydraulic-Tool/201590947261?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D39836%26meid%3Deb476f4f230641a88c0c9f9892f83ce1%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D371662465547
  3. Advantage: ? Umm, it's noisy Disadvantage : Hot air intake, lesser filtration. Many more. If the 2002 Outback uses a MAF sensor, then you really don't want it because it changes the airflow charecteristics and therefore the tune will be off
  4. About a 2006-2007 Impreza or forester 2005 to 2008 will be a great vehicle within those requirements.
  5. You would have to scan and watch live data.. If its not reading cold enough it could be doing that. Ecu always uses coolant temp.
  6. The phase 1 ej20 is a JDM equivlant of the usdm ej22e. Beware there are phase 2 ej20 also. Either will work for u. Just know what year engine your getting and match wiring and ecu to that
  7. I'd use JB weld type stuff for sure. Its not structural and will work fine.
  8. 1998-2001 Impreza center console will also work. The ecu is trans specific so you will also need a compatible ecu. 2000-2001 Forester or Impreza should work. The pedals for a '93-01 Impreza will also work. Or a forester up to 2001. Trans mount might need to come from a forester I'm not sure. Chassis is the same but the forester uses subframe spacers like an outback
  9. Yes I both would tow that with ease. I would recommend forester tho. Auto wrx are really de tuned. Not really worth the added turbo maint expense
  10. Battery manufactures consider a battery running 80% of their capacity a good battery. So 440 out of 500 cca, that is right at 80%
  11. I don't think they exist. I had a 1999 Legacy SUS 35th Ann Limited and if they were available, it would have had them. But it didn't
  12. Yes, cam and crank sprockets might be different. The only way you can be sure is to compare. Beyond that, the 2001 engine might not have an EGR but the 2003 engine should have one if it's an EJ253 I think. EJ251's were still used in 2003 though. You will need to keep the original intake manifold with the car. They are not interchangable
  13. I don't even think all EJ22's had them. I know the '96 EJ22 that I did gaskets on did not.. But it should work fine if you drop one down.
  14. Forester S and XS, and high optioned Outbacks from about 2000 onward have 4.11 or 4.44 lsd
  15. Do your rules allow an AWD? Any 4cyl class around here has a 2wd/FWD rule. They DO run Subaru's ( First Gen Leggy's take a beating before they quit too ). But, they are required to disable the AWD. The tracks know about the FWD fuse and not to allow a M/T that isn't somehow modded like a welded center with cut rear CV's
  16. Thats what I was thinking of. No wonder the site looked different than I remember
  17. I tried to look it up with Opposed Forces. but it only goes back to 1993 EDM which did not have a turbo at that time.. The other resource is www.japanparts.com which has part diagrams and you can gain part numbers. You could also order from them. Sites a bit slow tho Partsouq requires a chassis number to look up parts. Otherwise you have to search a P/N yourself and see if they can get it.
  18. Usdm ej25D should work. With a JDM, opposed forces is your friend. An EDM will be close enough for not to. It will tell u if something crosses. Www.partsouq.com gets stuff from overseas quickly.
  19. With a 1-2 year old Subaru. It never pays to buy used. 2015-current dropped the xv designation. And reverse cam is std. Beyond that, you really just gotta find what you want and used really wont be cheaper
  20. Anyone know if SG A arms will provide the correct geometry if I use them in conjunction with a '02-'04 WRX/ Forester XT crossmember ( they share same P/N )? I know the struts swap. Essentially since I'm planning on using a WRX crossmember, I know my balljoints are probably stuck in the A arms and it would make sense to get cleaner ones anyway, and to get ones that wouldn't need shimmed. And then I could also use the FXT swaybar since the suspension would be SG
  21. The easiest way to figure out what you have got is, the trans code by the starter. That will give you the trans ratio.. If your front diff is 4.11 or 4.44, just match it to the rear diff of the same. Foresters used 1:1 center diffs so same front and rear. Unless the PO used a 1.1:1 center diff, then it could get messy but I THINK the 1.1:1 center diff was a USDM WRX M/T thing only
