matt167
5
Everything posted by matt167
Phase II EJ251 into 95-98 Legacy questions
matt167 replied to janas19's topic in Subaru Retrofitting
It's more common than you might think.. Find an old work van and set up shop in the back. -
Decent hydraulic compressors cost about $130. If your going to do 4 struts, a shop will probably charge $20 per strut to take the time and do it and many shops will look at it as at least 1hr of labor.. So that's gonna be $80-100 plus the gas to get to a shop.. If your planning on 4 struts, just buy a $130 compressor. http://www.ebay.com/itm/New-Coil-Spring-Compressor-6600-LBS-Auto-Strut-Hydraulic-Tool/201590947261?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D39836%26meid%3Deb476f4f230641a88c0c9f9892f83ce1%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D371662465547
1992 Subaru Loyal Engine Swap
matt167 replied to dirtyloyalemobbin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The phase 1 ej20 is a JDM equivlant of the usdm ej22e. Beware there are phase 2 ej20 also. Either will work for u. Just know what year engine your getting and match wiring and ecu to that -
1998-2001 Impreza center console will also work. The ecu is trans specific so you will also need a compatible ecu. 2000-2001 Forester or Impreza should work. The pedals for a '93-01 Impreza will also work. Or a forester up to 2001. Trans mount might need to come from a forester I'm not sure. Chassis is the same but the forester uses subframe spacers like an outback
Towing opinion
matt167 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes I both would tow that with ease. I would recommend forester tho. Auto wrx are really de tuned. Not really worth the added turbo maint expense -
Battery manufactures consider a battery running 80% of their capacity a good battery. So 440 out of 500 cca, that is right at 80%
- 34 replies
- 2004 Forester
- leaky head gaskets
(and 3 more)
Tagged with:
Yes, cam and crank sprockets might be different. The only way you can be sure is to compare. Beyond that, the 2001 engine might not have an EGR but the 2003 engine should have one if it's an EJ253 I think. EJ251's were still used in 2003 though. You will need to keep the original intake manifold with the car. They are not interchangable
Do your rules allow an AWD? Any 4cyl class around here has a 2wd/FWD rule. They DO run Subaru's ( First Gen Leggy's take a beating before they quit too ). But, they are required to disable the AWD. The tracks know about the FWD fuse and not to allow a M/T that isn't somehow modded like a welded center with cut rear CV's
I tried to look it up with Opposed Forces. but it only goes back to 1993 EDM which did not have a turbo at that time.. The other resource is www.japanparts.com which has part diagrams and you can gain part numbers. You could also order from them. Sites a bit slow tho Partsouq requires a chassis number to look up parts. Otherwise you have to search a P/N yourself and see if they can get it.
With a 1-2 year old Subaru. It never pays to buy used. 2015-current dropped the xv designation. And reverse cam is std. Beyond that, you really just gotta find what you want and used really wont be cheaper
Anyone know if SG A arms will provide the correct geometry if I use them in conjunction with a '02-'04 WRX/ Forester XT crossmember ( they share same P/N )? I know the struts swap. Essentially since I'm planning on using a WRX crossmember, I know my balljoints are probably stuck in the A arms and it would make sense to get cleaner ones anyway, and to get ones that wouldn't need shimmed. And then I could also use the FXT swaybar since the suspension would be SG
The easiest way to figure out what you have got is, the trans code by the starter. That will give you the trans ratio.. If your front diff is 4.11 or 4.44, just match it to the rear diff of the same. Foresters used 1:1 center diffs so same front and rear. Unless the PO used a 1.1:1 center diff, then it could get messy but I THINK the 1.1:1 center diff was a USDM WRX M/T thing only
