matt167
5
Everything posted by matt167
I hadn't either until a post on facebook. And then one day I was without a c clamp but had a caulk gun, so I proved yep it works.
- 11 replies
- Brakes
- brake pads
(and 2 more)
Tagged with:
Flip it upside down over top where the line connection is on the back, and then the plunger will ride on an old pad. Its not the best way but it works.
- 11 replies
- Brakes
- brake pads
(and 2 more)
Tagged with:
Takes me less than an hr to put pads on all 4 corners in a parking lot.. With a Subaru, all you need is a single wrench, brake grease and a heavy duty caulk gun to do the brakes.. You can use a c clamp or a brake piston compressor if you wanna get fancy. But a caulk gun works fine
- 11 replies
- 1
- Brakes
- brake pads
(and 2 more)
Tagged with:
If I open them and put them right back, it won't hurt will it? I know the standing rule with Subaru A/C is they don't 'need' evacuated to work sufficently. But I don't want to buy a compressor till I know it's worth messing with.. I'm at 228k miles but only 10k of them are mine so it's still an unknown car really
2008 or 2009 got selectible shift but was a 'speeded' auto. CVT's came in 2010.. The FB 2.5L ( timing chain ) came in 2011 in the Forester and 2011 in everything else except Impreza went to a 2.0L version Mechanic is right. As far back as 2000 at least, the H6 runs a chain. The current H6's run a 5spd auto
2001 legacy
matt167 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
99 lego is phase II/ EJ222 as is 2001 251/253 -
2001 legacy
Yes. They are functionality identical but single port exhaust -
Has been seized since I bought it. Winter wasn't bad but now its hot and this car just does not blow cool air from the vents like some do. Car part shows a 2001 Impreza going back to 1998 cars but 2001 forester only goes 2001-2002... Local place has both but Impreza listing brings up a $45 one, other is $65 for forester
My 2001 Forester locked me out of it at the gas station. Its good that the hatch does not lock cause that was my way in.. Same trip the locks began locking rapidly. Sometimes it was triggered by the headlights? Then it would lock when the door closed and arm. Fobb would disarm but not unlock.. When I got home I reset batt and it seems to be better but car still locked itself next morning. Can I install an aftermarket system using the original box connections? I see boxes are around $50 but this seems like a common issue with them, the grey button fob system I mean. I have an old audiovox kit that has never been used.
The dual range transmissions are not hard to find from jdm importers but getting the shifters and consoles is pretty much impossible. Ea dual range shifters can be adapted but isn't 'right'
- 96 replies
- Dual Range EJ
- LatinAmerican Domestic Market
- (and 7 more)
