matt167
5
Everything posted by matt167
Oil consumption test is done with a fresh engine usually. You get the test initiated, drive until the low oil light comes on and go back. Low oil light is 1 quart low. Subaru has a 1,200 mile threshold for oil usage. If its over 1,200 miles they call it ok. If its less they short or long block it depending. My mom had her 2012 Impreza done and it went from 1qt in 700 miles to zero usage. It dropped from a 1,200 mile usage quickly
Old brat in new hands
matt167 replied to Norcalbratcap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The EA filters are a different thread than EJ engines, and are only common with them and some pre 1996 Nissans. Its unlikely Subaru still makes filters for the old gens. Just stick with the wix -
If you gotta rewire it, forget NA stuff and get a Wrx harness and ecu. Then build something from that..
- 11 replies
- Subaru legacy wagon 1995 swa.
- Swap help
(and 2 more)
Tagged with:
SVX paint
matt167 replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'm lucky, my white 2001 Forester is nearly an exact match to rustoleum pro white. Either gallon, quarts or spray can match. -
Give these guys a call and see how many hours a Unimog clutch should take.. They do Unimogs, tanks and a lot of other Military vehicles.. usually have 3-4 Unimogs around since they buy and sell them. Millitary Collection Grand Gorge Ny, 12434 (607)588-7002
Engine swap
matt167 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Cam sprocket and driver cam pulley swapped? -
95 impreza
With a 1995, you will have an easier time with 1993-1999 stuff. The dash from an 01 will fit physically but not electrically. You would need to merge harnesses and at that point you might as well just do a WRX swap and make a faux 22B or R-STI since you have a 2dr -
What is your engine code found on the drivers side strut tower EJ253?. have you tried std bearings? The ID clearence should come out somewhere around 55mm due to oil clearence.. Stock and any crank that I know of does not use anything but a 48 or 52mm so it's unlikely.. Truthfully, unless you want extra HP, there is no need to rebuild an EJ engine. Drop in a 1999-2011 EJ25 short block, use your heads and intake.. get lowest mile you can but, engines gonna run less than $1k most times under $500
resource conserving = marketing speak for recycled
Engine swap
Yes, the EJ222 sometimes uses a MAF/MAP combo system depending on model, and the EJ251 Forester is straight MAP system -
2000 forester
Tranny might as long as the 2004 Forester uses the same 4.11 gearset, dash will fit, but electrically may not function. I personally hate the 2004 HVAC controls. Those touchy twisty controls are just horrible.. The good old sliders on the 1998-2002's is much better
