matt167
5
Everything posted by matt167
Subaru prior to 2005, the rear O2 does nothing to the fuel trim or open/ closed loop. All it does is light the CEL and throw P0440 if somethings amiss with the cat.. Subaru after 2005 will alter the fuel and ignition map to attempt to correct the catalyst efficency if it's off.. Using an anti fouler on 2005+ electronics would be a bad idea.. My 2001 Forester has had an anti fouler in the Cat since about a week after I got it ( burned out cheap aftermarket cat ). No ill effects and CEL hasn't come on
Tire options
matt167 replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's super expensive for a 50k mile tire depending on the tire brand/ model and it sounds like it's an el- cheepo for an all in one type deal.. Consider this. a 4 wheel allignment is only $60-80 in most places, and a production tire shop is NOT where you get a good allignment. tires your wanting are in the $80 range from there.. Most places offer free mounting but charge $5-20 for balance. $10 for road hazard ( yes, it's not really free. you can usually opt out despite the sales pitch ). Walmart or Sams gets what is called "Priority" tires.. This is a tire made specifically for them. They buy a set amount, and that's what gets made.. They are generally less expensive versions of a tire that's in the regular lineup.. ( Goodyear for Walmart, Michellin for Sams Club ) I would buy 4 new tires from Walmart. Go for the Douglas All Season, Douglas Performance or the Douglas Xtra Trac II ( if there still available, they have been discontinued due to tooling changes ). The Xtra Trac used to retail for $57 IIRC. You would be out the door approx $250+ tax on 4 tires with lifetime rotate and balance -
97 Legacy wagon
Sea foam is alcohol, water and pale oil. Its a decarbonizer that should be added via vac line or thru the intake or carb. It was never designed for gas or oil tho the marketers put it on the can. Originally it was designed to decarbon outboard motors, hence seafoam -
97 Legacy wagon
You need 4 tires. No tires are exactly the same diameter, so regardless of tread depth. If there mismatched, they need replaced.. I wouldn't do Viva 3 tires, there over rated, cheapened Eagle RSA. I would do Douglas Xtra trac II if you can get them, or the Douglas All season which is the Xtra Trac replacement.. $9 lifetime rotate and balance, free.mounting. You can't beat a good TLE. -
If it runs ok, just run it like that. Yea some of the valves probably bent but if it's not missing or throwing a code it will be just fine... My brother ran a 16V Kia engine that had a broken belt, and it ate all the valves since he said it sounded like marbles when it let go... But stuck a belt back on that car and it still ran ok for another 50k miles.
One of the things that has bothered me on my '01 Forester is the rear hatch is rusted out where the wiper goes thru. someone stuffed it full of bondo but it looks like crap, and leaks I'm sure, tho I have never noticed water I had to replace the hatch latch due to it being rusted solid.. I took the latch from a '98 Forester that was same color, sadly I did not have the means to get a hatch home that day and they crushed it before I got back to get it.. Same yard is having an upcomoing sale soon, so I may just have to grab one. They are normally $65, but on sale could be as low as $30.. Where are the connectors that go to the hatch? I know the hatch/ hinges are straight forward.. And will the hatch fit into the car with the rear seats folded? I don't have a truck anymore
2002 wrx
matt167 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Right, and a stock used STI up pipe won't be expensive at all.. STI's were exempt from the strict emissions crap since every manufacture was allowed 1 model to exempt back then.. You could use one off any '02-'07 STI and it will be a catless up pipe -
2002 wrx
It's an '02, so you can use an 18mm spark plug anti fouler, drill it out and put the rear O2 sensor in it. the ECU does not use that sensor for anything else except tripping a catylist inefficency code
