matt167
5
Everything posted by matt167
More work than if u just pulled the engine... Yes it could be done, either drop trans or you could use an atv jack to slide engine forward and you could probably gain enough room if you stood on your head from the top... If you got a solid tree or rafters that can hold a few hundred pounds. Go grab a 1 ton chain hoist for $30 and work in comfort
I've done a few ej22e,s but never an interference sohc. How do I safely rotate the cams and crank without hitting valves. I seem to remember that with the crank lined up on the mark, all cylinders are below top dead center. I'm considering bumping the engine over with belt in place till they are on the marks.. That seems safest. I'm just doing the belt and 3 idlers. Engine has oil pressure issues and a cold knock. Just have to keep the heads safe so I can use them on my spare short block when time comes. Gonna borrow tensioner from same block since it had a fresh complete timing job when I bought the car it came in.
tires
matt167 replied to Chrisatjub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Wheel width has a factor in the final height and width.. Every tire has an optimal width rim and the tire is measured from that. This is why brands have variations -
Worst case it hurt the bearings, possibly weakened the rods. It probably didn't go that far but could have. Just use the 50\50 since you don't know your current amount. It's same as concentrate but mixed with distilled water. Personally, I use concentrate and tap water on daily drivers. That was good enough for a long time till the coolant companies started charging extra for some distilled water
Well, I grabbed some belt dressing from the parts store as a test. I was able to duplicate the noise putting it in 2nd with the brake held and lugging the engine a bit. That was BEFORE... Now after the belt dressing, I can't hear the squeal, just the silence of a lubricated slipping belt.. So, I think I need a new belt. I could probably try some abrasive cleaning powder to save it, but a belt on a Subaru is pretty cheap and I might even have one from my other car.. Good to know about Gripforce.. If they send anything but an Exedy, it's false advertisement and Paypal/ Ebay would see it the buyers way every time. False advertisement can be considered fraud and thus is illegal.
P0128 code
matt167 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
coolant temp sensor is probably reading slow.. the code relates to how fast the engine heats up -
Random knock
matt167 replied to Cobrae's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Rod knock. clearences expand when it's up to temp.. You had enough clearance for it to light the oil light which is less than 5 PSI IIRC... If you wanna try running it still. Baby it and switch to 15W40 oil and run it till the rod wants out
