matt167
5
Everything posted by matt167
My '01 Forester just started squealing when starting on a hill in 1st. goes away once it's run up into 5th. Sounds just like the belt squeal from turning the wheels lock to lock does sometimes. The belt is slightly worn, but not enough to make me do anything about it yet ( till now ). If I push the clutch in, it will fade away pretty quick just as once it's in 5th, it fades away quickly.. Could that be the throwout or is it just the belt slip? Can I run it like that if it is the throwout? I'm prepared to do a clutch. have the tools, have the cash just short on time since it's my only vehicle.. I was looking at Grip Force FX stage 1 clutches. An OEM Exedy flywheel, throwout and clutch is only $165, and their stock replacement clutch with the same stuff is $157.. I was thinking stage 1 since at some point, this cars gonna tow a boat that is just shy of 2,000 lbs fully loaded. Realistically it's about 1,800 with gear in it.
I've changed lots of rear differentials in various vehicles, but only one other Subaru and that came out a dark honey color.. I just changed the gear lube in my Forester because I'm starting to think it's gear whine and not a wheel bearing.. The plugs were corroded shut so I had to use the jack on the socket wrench trick.. The oil came out clean and light colored. the magnent had a bit of crud on it but not too much. I'm thinking that oil was very fresh because someone else came to the same conclusion and tried the same thing.. I filled it back up with 80W90 GL5 conventional. store didn't have 75W90 and I know in my 230k mile car it's not going to make much difference anyway.. Now comes the question. If it is gear whine and I need a new differential. what is the gear ratio for a 2001 Forester S 5spd? I was thinking it was 4.44 but I want to make sure, and what models I can get one from. The local U pull has plenty of Subies that as long as it does not need to come from a 5spd Forester I should be able to grab one.. There like $50 OTD
2000 forester
matt167 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Use what the car came with for all. That will ensure it runs right -
The 99 Lego sus that i had, ran perfect till it got to about operating temp. At that point it would skip so bad it was dropping cylinders. Shortly after it was blatent overheating. After I pulled that engine, I checked the plugs and they were clean and smelled like coolant.. A weeping gasket with a little coolant in the cyl would do it and the exhaust gas might not even make it in if the gasket is still sealed for the most part
I just had a rear wheel bearing done on my '01 Forester. Was going to pull the knuckle, take it to Napa and have them press it and do everything else myself but I just didn't have the time and I've also never done one, so I took it to my buddies shop.. When I picked it up, he billed me for 2.5 hours extra because he had trouble with the long knuckle bolt and that's the time it took. I didn't even think about that bolt, but I've read about cutting it in half and knocking the halves out backwards due to this issue.. I may have to do the other side. What is that bolt called? I figure I'll just buy one and it will be less than 2.5 hrs labor.
it has vent caps. pop them off and drop 1 non coated asprin in per cell.. should revive it if you don't want to replace it yet
synthetic oil only comes from a couple different bottlers... I think you will find that the Castrol Syntec and Penzoil Platinum are pretty much the same
'should' actually be a 251 also.. But, 253's used MAF sensors, 251's used MAP sensors... Engines themselves until 2004 would actually be the same, since it's a minor electronics difference.. The EJ251 vs EJ253 is really only part of an engine type code. In any case, swap intakes and run the '253'. You may need to swap cam gears around to get sensors to read right, but you have an engine out of a junkyard. it needs a new T belt and idlers anyway
Oil Filter
matt167 replied to keith3267's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I only install FRAM because I'm paid too
