![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
matt167
5
Everything posted by matt167
Well, a 2.2 in a forester isn't factory correct and the fact that everything fits means and parts books are often wrong. just don't get detailed. Make it work... You can use whatever coil you want for a 1995-1998 ej20-25 electrically. Possibly even older. You just need to swap connectors. Beyond that coils wont work.. The connector that clips onto the coil started in 1997. I dont know which year your looking at but it all seems plausible.
165R-13 tires Les Schwab
matt167 replied to Silas Cruse's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I agree. 165/80/13 or 165/70/13 both will be 'about' the correct size for your car. Both still have name brands available. 165/65 13" might also work. -
Automatic Forester is 4.44 geared in the USA with a 2.5L. Pretty sure the automatic 2.0L JDM Forester is also 4.44 geared. But they live at speeds no higher than 100 km/h.
- 8 replies
- timing belt
- engine swap
(and 2 more)
Tagged with:
Tons of NA-T Subaru's running around on moderate boost with factory compression. ( 10 PSI is pushing it ) ECU's before 2003 don't fight it too much.. RS-25 and NASIOC are 2 good places to get info.. As for ECU tuning, Project Lambda tuning will tune the factory ECU if it is a JECS Ecu. Won't work for a Denso but that should be JECS anyway
that's an actuator or lever that locks what would be the center diff on an AWD car pretty sure ( have not been around an EA in years ). That's how it worked on the old 4x4 EA cars. The AWD Automatics use a solenoid to operate a clutch. Provide constant 12v to the solenoid or cut the power makes it 4x4 or fwd depending... The manuals just use a viscous coupling in the center differential. You could have a machinist make a mechanical disconnect/ sliding mechanism but it would be expensive.
How much $ would you pay for a distributor to fit EJ ?
matt167 replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Megajolt I think is derived from mega squirt I think using only the ignition portion and their custom software. In the case of MS, the wheel that works is 36-2-2-2 but it works fine with the right settings. If you look up the crank sprocket for a 2004 USDM WRX then you'll get the right part. It was used in many others dating back to as early as 1999 -
personally, I'd use the ignition portion of a Megasquirt 2/ Microsquirt to run the DIS setup. Just use a 36 tooth crank sprocket and sensor from a later EJ. That's all MS needs to run ignition only -
Most states that do a plug in test allow one system not ready. A CEL is illuminated after the system test fails twice. If it fails only once it goes into a pending code and that system is set to system not ready.. So if that is the only system not ready it is ready for emissions testing.. The system ready/ emissions ready is programmed into the ECU
Battery Help
matt167 replied to WhtMke's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Walmart value line is 500cca for $50. They work fine, and as for your battery it likely has a weak cell. These engines only need about 400 amps or so to spin them over reliably. The factory supplied Panasonic batteries are around that -
That is the positive feed to the battery. The other end bolts on to the battery cable near the battery. Run a new cable from where it bolts up. It's damaged, draws too much current and burns up.. You can use lawnmower battery cable as a quick and easy fix. Sold everywhere including Walmart and is has ends you can use on it for both ends
- 9 replies
- 1
- Alternator
- Short out
- (and 4 more)
switch the pin on the ECU so that it turns off the TCU. Then you'll just have to convert the wiring to M/T and it'll run. Swap the pedals and console, rear differential and that pretty much makes it up.. Cruise probably will not work, or not correctly Swapping a '98 Foz is one year only phase 1, and the swap is basically same as any phase 1 car
