naldo
About naldo
- Birthday 04/20/1990
Gender
Male
Location
Deltona Florida
Interests
cars
Occupation
studying ME
Referral
ej25 swap
Vehicles
2005 Forester 2.5X
naldo's Achievements
Advanced Member (3/11)
5
Hello guys i have a 05 forester which recently i change the motor on. In the time i have the car it has started to make knocking noise which i think pretty sure comes from the torque converter i am not sure if the rocker arms can make that noise keep in mind that the head where machine shop, but it does the noise when ever i rev the engine or whenever i have the car in reverse of neutral/ stationary at a light. The car runs great shift fine and has no driving problems any idea on what it could be ?? Any suggestions will be gladly appreciated
Torque Converter
naldo replied to naldo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
ok so the i changed the motor recently and the torque converter fell offf while removing the engine is was put back together but i am not sure if the person put it in the right way,, i know definitely that is not rod or bad valve because i did i sound check and it come directly form the torque converter so that's why i wasn't sure some times when i stop at a light it feels like the car wants to shut off but it doesn't like the rpms fall under they suppose to be but it levels out again -
hello guys i have a 05 Forester and recently my torque converter is making this weird sound like metal knocking around in the converter, the forester runs finds but the noise is annoying and i was just wondering what could be causing the noise in the Torque converter also it started doing it on park and now it does it on park , Reverse and even on Drive soo i am pretty sure is getting worse everytime i drive it
ok guys so I found more information on the car here is the list : Drivetrain is stock suspension BC coilovers perrin rear sway bar legacy gt rear brake conversion upgraded bushings CNT downpipe, greddy exhaust, koyo alum radiator tune OTS XTP stage 2 flash timing belt done 113,000 mile ago 2 owner doesn't know if water pump and head gasket has been change he told me he has not changed it himself so its unkown since he bought it about 113000 miles ago are the opinions still the same after this added information ??
Thanks guys I appreciated your opinion I just wasn't sure if it was a good idea, because a lot of people that I have ask they don't own Subaru and tell me to trade it because you know is a WRX , but if what you guys are telling me is true, then I will think it twice before doing, the trade . I appreciate the opinions
Hello everybody , I am planning to trade my 05 Forester for a 04 Impreza WRX and wanted to know if its a good deal 05 Forester specs: New motor with 70,000 miles The body has 211,000 paint is good and interior is perfect tires are brand new has a/c kenwood stereo brand new Ujoints shifts good It has one bad O2 sensor everything stock 04 Impreza wrx specs: 171,xxx miles on the car turbo manual 5 speed, don't know if transmission is good good paint XTP stage 2, down pipe exhaust coilovers blacked wrapped in matte white vinyl No good tires Any suggestion whether I should make the trade or not
I feel it more in front of my seats not under . when you feel it feels like the whole front end is shaking . The steering wheel doesn't shake by the way only the front end of the car , and like I said its only when I am accelerating from 50-55 and 65-70 , when I let the pedal off its stops shaking but when I press the pedal again at those specific speed it will start all over again
