Hello all,
I'm new to the forum, but need help. I don't wont to replace my Forester but I might have to due to the new emissions testing laws.
Background:
Bought this car in 2006 from a dealer with 60k miles. 4-cylinder 5 speed manual ("L" class)
At 105k replaced the clutch
Has run and preformed above and beyond for years, great MPG and other than the clutch no major repairs.
Car now has 206k miles...
10 months ago failed emissions testing in Colorado for high Knox Got a check engine light after that for a P0172 System too rich. Replaced the upstream O2 sensor (before cat.), ran AMS oil injector cleaner, used premium gas, and passed emissions.
Check Engine Light is still on for system too rich, idle is getting rougher by the week and has started to "bog down" when starting from a stop then suddenly finding it's power and surging forward. If i run the RPM up to about 3.5k and let the clutch out slowly it dose not "bog down".
By "bog down" I mean the peddle is to the floor and it dose not go, engine has a 'putting sound' real dull like there is no spark.
Shortly after the low end problem started things got worse. One or more cylinders started pre-firing and the car began to jerk front to back, changed gears and it happened again within 10 sec. Limped the car home and did some digging.
Replaced the MAP Sensor and reset the on-board computer by unplugging the battery. No change, replaced plugs and wires, no change.
On a suggestion from a friend, unplugged the O2 sensor I replaced 10 months ago, when the car is cold there is no change, still rough idle and still a wild ride. When the engine reaches normal temp, the idle gets better, still not factory smooth. The engine stops pre-firing but still cuts out ("boughs down") every now and then.
Sorry for the log post but here is my question. I have been to Auto Zone and they provide me with the code P0172 and a list of parts to replace including O2 sensor, MAP Sensor, Fuel filter, Fuel ejectors and a few other things. I don't have the money to just go replacing things and hope it works. Can anyone point me in a good direction or have any ideas? My other thought is I have to get emissions tested again in 14 months and I have had some people suggest my Cat. converter is "burned out", is this related to the other problems I'm seeing or is this different?
Thank you in advance.
Travis
