risonm92
About risonm92
- Birthday 08/16/1992
Gender
Male
Location
Martinsville Indiana
Occupation
NAPA Auto parts (Southern Indiana Auto)
Referral
Friend
Biography
I recently acquired my first Subaru!
Vehicles
94 loyale wagon 4x4
risonm92's Achievements
Member (2/11)
0
Thanks Kanurys theres a load of good info in your thread.
I don't doubt you but im just curious as to why strictly Subaru seals?
Can I get those in a kit? Or do I have to buy them individually or what?
Well after procrastinating for a week or so I finally tore the motor down to the point where its just the block with crank and pistons. First thing I did after taking all the accessories and intake off was remove valve covers and 3 outta 4 (sound familiar?) of the intake lifters were just chilling in there not doing a damn thing so they deflated and that was my problem.. million dollar question though is why??? Cylinders are still cross hatched and everything else seemed in good shape. Not sure why I put this off for so long it was incredibly simple.
Also on a somewhat side note can anyone tell me whether or not an ea81 alternator bracket would mount on an ea82 my compressor is shot and I don't feel like replacing it seeing how I seldomly use ac anywho. Just curious I'll have to address that sooner or later as well.
haha that's awesome but knowing me and my luck I wouldn't be as fortunate as you to just be able to throw timing belts on like that. After work today im gonna drill the remaining ones out.
As northwet said my readings on 3/4 cylinders was 35 or less and only 1/4 was about 170. Anyways ice got it down to just the block and heads and timing belt covers im fighting with the covers because every single bolt holding them on is rusty beyond belief.
How common is it for these engines to lose compression for reasons other than a blown head gasket? If I don't HAVE to I'd rather not pull the whole thing apart just curious.
..and its not an ea82t and I know it's underpowered my friend has an 85 brat and my secondary car is an 85 Toyota tercel wagon 4x4 with a massive 65hp so im well aware
Yeah its pulled and on my hoist not exactly positive how to mount it on my stand its a conventional stand and the ea82 is far from a conventional engine haha would I just put the studs through the bottom arms on the mount with some grade eight bolts through the top?
So im getting ready to start the tear down on my 94 ea82 any tips tricks or advice on doing this other than of course documenting and label things.
ok then. Do you know of any companies that produce a larger cam for an ea82 and ill look into the throttle body idea if you happen by it id appreciate if you kept me in mind and passed on any info
- 20 replies
- ea82
- horsepower
(and 2 more)
Tagged with:
Pretty much 3 out of 4 cylinders were dead for whatever reason the 3 had 35 or less when checking for compression and one had around 170. Once I'd pressurize the bad cylinder I'd hear a distinct air sound coming from the oil tube and nowhere else. So I figured it was rings or at least something internal that needed fixed. That's the purpose of the rebuild in the first place.
- 20 replies
- ea82
- horsepower
(and 2 more)
Tagged with:
I'll more than likely just do a stock build based off of what everyones saying and what I've researched.
- 20 replies
- ea82
- horsepower
(and 2 more)
Tagged with:
94 Loyale wagon starting/running issue
risonm92 replied to risonm92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To my knowledge there was no oil consumption and I would imagine if it were a hg issue when I pressurized any of the bad cylinders as I did there would've been bubbles from the antifreeze which there was not but im not ruling anything out it's anyone's guess right now lol
